-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   swaping DME's (http://forums.pelicanparts.com/showthread.php?t=15224)
justin 11-04-2001 04:40 PM
swaping DME's
I have a 83' 944 and was wondering if I got a 85.5 DME can I swap them and still be able to chip,if it will even work?
Drive it like you stole it........Justin
951carter 11-04-2001 06:44 PM
the idle stabilizers are different but i believe it will still "work"
Carter
"Rehab is for quitters"
Obin Robinson 11-04-2001 07:33 PM
<font face="Verdana, Arial" size="2">Originally posted by 951carter:
Carter
</font>
any more info on this? i was interested in going to a newer DME also! i noticed that a few small things would have to be changed, but i was not certain about voltage, resistance, and capacitance levels of various sensors that the DME uses to do its job correctly. is the idle stabilizer something that can be swapped out from a later model for it to work correctly?
thanks!
obin
951carter 11-04-2001 10:20 PM
yes, the idle stabilizer i know can be swapped out.the computer "swap" is speculation as i have not tried it personally but have "heard" of others doing it succesfully.
justin 11-05-2001 08:45 AM
Lets keep this thread going,I want to figure this one out.
EGSMachine 11-05-2001 01:06 PM
they are cheap enough on ebay, if you don't blow it up in trying the swap, you can resell it on ebay.
