Post rear bumper shock
86 NA-
my passenger side rear bumper is pushed in a little, which is causing the plastic on the side to bend and push out. Can this shock be pulled back out? or replaced? i noticed there is a screw underneith the bumber that looks like it may adjust the fluid inside or something?
Does anybody know if that plastic peice on the side is replaceable?
If anybody knows where to get either the shock or the body piece (a url) or how much, that would be a great help.
Thanks!.
paul
Old 09-23-2001, 12:41 PM
Composite Shop Owner, DJ
MixMasterK's Avatar
Send a message via MSN to MixMasterK Send a message via Yahoo to MixMasterK
Post
DO NOT PULL on the bumper shock! You are endangering yourself if you do! One of the top lessons learned in frame pulling. Remove the bad shock and replace it with a new one. Tweeks or Perfomance Products and possibly Pelican carry the shock.
Old 11-05-2001, 05:26 PM
AFJuvat's Avatar
Post
I'm not sure if they are the same or not, but if they are, I have a used front one you can have for the cost of shipping.
AFJuvat
Old 11-05-2001, 06:05 PM
