Blackfoot's Avatar
Oilpan leakage
My RX-7 w/Nissan engine has developed a nasty, voluminous leak in what I have determined is coming from the oilpan gasketure. Actually, this engine has two oilpan-looking things, a smaller bottom, and a larger, intermediate pan. Here are some pics.
First small pan off
Small pan with proposed gray RTV
In this next shot, you can clearly see where gray RTV is used as a gasket between what I call the intermediate oilpan and the engine
In taking off the small pan, it shows that RTV or equivalent is the factory method of sealing. My question is, would cutting out a pattern in gasket material and using it instead of RTV work better? Combination gasket material & RTV? Other?
Also, noticed an interesting thing when the small pan came off:
Yup, the oil scavenge was broken clear off. What could have caused it to snap?
The intermediate pan is 3x longer and will come off tomorrow. Any sealing ideas would be much appreciated.
______________________
Cars
Old 03-28-2004, 12:43 AM
AFJuvat's Avatar
I woulds confirm that grey RTV was the factory approved method of sealing it. Usually with RTV, the sealing surfaces have to be clean, dry, and oil free until the RTV sets up.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-28-2004, 05:50 AM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
another option would be to get some gasket paper, or better yet, a sheet of neoprene and spent 10 minutes with a razor blade and a cheap gasket punch set. There's nothing particularly magical about most pre-cut gaskets (I do say most, as there are some exceptions, like the VW steel core neoprene valve cover and oil pan gaskets which really are easier to use than roll-your-owns)
I suggest neoprene because if it is installed on a clean, dry surface it can be resued 3 or 4 times without replacement. Therefore if you're going to use it, either install without sealer or adhesive, or else glue it to one surface only (so it sticks to that surface next time you disassemble)
nate
1988 944... and a bunch of other cars
Old 03-28-2004, 06:14 AM
Wolf1's Avatar
Blackfoot: I would suggest using the RTV and no gasket material. It was designed this way and works well if used correctly. As AFJ said keeping both surface areas clean and dry are critical.
I personally would use the sealant available from your local GM dealer, it works much better than any other that I've seen. Hey, if it can keep a Chevy from leaking, it's got to be magic..
p.s......still need the 951 clutch lever...
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 03-28-2004, 08:44 AM
Blackfoot's Avatar
Thanks for the replies. The Neoprene idea sounds interesting, and I might try it if the RTV solution doesn't work.
_______________________
Cars + oil
Old 03-28-2004, 10:58 AM
gearhead290's Avatar
Send a message via AIM to gearhead290
Nissan does things for a reason. Remember, Nissan makes good stuff.
What engine is it in ur 7? I've heard of quite a few SRs showing up in them...
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 03-28-2004, 07:09 PM
Blackfoot's Avatar
It is a SR20DET red-top, putting out insane hp.
___________________
Cars
Old 03-28-2004, 09:11 PM
