how tight should wheel bearing lock nuts be tightened?
My S2 has all new front suspension parts. Everything has been replaced and torqued to specs. However, when going over speedbumps, there is definitely something loose. I triple checked everything and discovered the wheel bearings were the source. When I tightened the locknut more, the "clunk" was reduced. I read where the nuts should lock down, then backed off a quarter turn. When I do that, the looseness returns. When I lock the nuts down until they stop, the rotor still turns easily. What is the proper setting? If backing off causes it to be loose, then what is going on? btw, not only does it make noise over speedbumps, but the steering wavers when loose. The outer bearings look to be in good condition.
'90 S2 Cabriolet
Old 05-26-2004, 08:56 PM
KevinBaker's Avatar
Tighten them down until they are tight, and then back it off ONLY enought to where you can move the washer with the tip of a screwdriver. I belive that is the proceedure I have heard of. HTH
Texas Greaseslingers-Have wrenches, will travel-Social Director?
Old 05-26-2004, 10:04 PM
AFJuvat's Avatar
It is likely that you have bad wheel bearings.
Tighten teh locknut until the lockwasher behind it can just BARELY be moved when you put lateral pressure on it.
Then tighten the allen bolt securing the locknut to 11 Ftlbs
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-26-2004, 10:05 PM
Thanks guys, but not sure that's it. I had the bearings checked by a porsche shop during a state inspection and they are fine. Everything is back together but the clunking sound is still there. It is definitely coming from the wheel vicinity and particularly over speed bumps. Again, it has new A arms, ball joints, shocks, tie rod ends. I wonder if there is something loose in the brake itself or rotor assembly such as a loose plate or something(?). Regardless, I know I'll track it down.
'90 S2 Cabriolet
Old 05-27-2004, 08:18 PM
SoCal Driver's Avatar
Sway bar bushings.
Tighten the nut at the top of the struts.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-27-2004, 09:11 PM
