MrPants's Avatar
is there a trick to removing front seats?
Ive been working on the front seat rail bolts for about 20 minutes now. they turn fine but they are not backing out any further. the rear seat rail bots came out fine.
If i try to lift the seat out it seems like the bolts are still holding it in but i cant figure out how.
is there a secret unaccesable nut that i cant see? any help would be appreciated
84 944 Non Alcoholic
Old 06-07-2004, 07:00 PM
Eli K's Avatar
no trick...I just removed mine earlier today for the first time. just unscrew the back and front rail bolts and pop 'em out.
Old 06-07-2004, 07:07 PM
ae1969's Avatar
Send a message via ICQ to ae1969
yours are stripped............
pry up the rail as you are backing it out.... and that will pull the bolt up
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 06-07-2004, 07:18 PM
SoCal Driver's Avatar
The front seat bolts on the early 944's have a floating nut under the sheet metal. These are rectangular pieces of metal that are held in place by more sheet metal. The nut rusts up and the sheet metal bends out. Prying up as you turn them may help.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-07-2004, 08:41 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Yep, other than that it's very simple - four 10mm bolts per seat. And four washers. That's it.
Black Cars Matter
Old 06-07-2004, 09:20 PM
A good soaking in PB Blaster would be a good idea too. Stuff stinks but it works.
Old 06-07-2004, 09:23 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Use a 1/4" drive ratchet. 3/8" drive is too big to fit between the bolt and the seat.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 06-08-2004, 12:19 AM
meister member
speedracing944's Avatar
Does the nut shift or fall out once the seat bolts are removed? How do you remedy bent sheet metal and rusted bolts before reinstalling the seats? Do you have to drill through holes and back up the nut with a large washer?
I haven't tried to take mine out yet but I plan on it tonight.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 06-08-2004, 04:44 AM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
yeah when i got my car the seats were loose so i tighted the bolts but they got loose again and now they dont want to tighten. is the only way to get them to tighten to either tap a new whole or weld them down?
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 06-08-2004, 08:07 AM
todwic's Avatar
You have to use new lock washers. Lock washers only lock once, after that, they're just a wierd looking spacer.
'86 951
Old 06-08-2004, 08:13 AM
It's typical of the front seat bolts on the early 944's to pull through the sheet metal. This is because they are designed to float for seat alignment and the sheet metal is too thin.
Old 06-08-2004, 09:17 AM
Send a message via Yahoo to bigyagi
be careful guys, dont let this get away from you! i discovered this one about 2 years ago. i was pulling away from my drive, and stepping on the "loud" pedal, when suddenly i was staring at the roof, with my feet caught up under the dash! if these nuts/bolts let go, and pull thru the light material, trust me, your seat will go rapidly backwards,and upwards and try to eject its self.
all i did to remedy the situation, was to remove an area the same width, and about 4 ins long. replace with substantially thicker material, and weld back in there. hmm, cant remember if i also did the same for the passenger seat. now this could be interesting for my girlfriend!
anyways, its really a good idea, to check it out, and repair, as it could have some serious consequences. i was lucky.
bob.
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 06-08-2004, 10:34 AM
MrPants's Avatar
haha man, you must be psychic SoCal, i just pulled the left side bolt right through the floor.
So much for not breaking more than i fix
Old 06-08-2004, 11:51 AM
MrPants's Avatar
damn it, im i going to have to weld something in to get the seat back in there?
The only reason im doing this is to fix the parking break lever so i can pass inspection. Im already more broke than i ever thought possible, i cant afford to have someone do work on my car right now and i cant weld.
Old 06-08-2004, 11:54 AM
Burn the fire.
Brando's Avatar
if you have just the rear bolts for the rails in, adjust your seat carefully I have only 3 bolts for my driver's seat in because the dip**** who owned my car before me used self-tapping sheet metal screws to put in some horrible non-compatible seats. You could always do that, too. Use some self-tapping sheet metal screws. Make sure the top sliding part of the rail clears, though.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 06-08-2004, 01:06 PM
meister member
I just removed my drivers side seat. It came out easily. I weighed it on the scale and it came in at a porkly 30 lbs. WOW.
Old 06-08-2004, 05:54 PM
MrPants's Avatar
Originally posted by speedracing944
It came out easily.
Rub it in my face why dont you?
Old 06-08-2004, 06:06 PM
If you think the early seats are heavy weigh a later seat with the electric motors and reinforced frame for the seat belt anchor.
Old 06-08-2004, 08:48 PM
