AFJuvat's Avatar
Its Baaaaaaack! Creative Engineering Part II
The car has returned.......
Complaints are:
Tension, but do not replace timing belt
AC not working
Instrument cluster not working - if it is a fuse, fix it, otherwise, don't bother.
Window still not working - do not fix unless it is causing the problem with the instrument cluster
Volt meter not working - do not fix unless this is causing said problem with instrument cluster
Top off automatic transmission - fix severe leak as long as it is not expensive.
Expect much hillarity and buffoonery to ensue
For background reading, go here....
http://forums.pelicanparts.com/showthread.php?threadid=139717&highlight=Socks
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-29-2004, 04:06 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
It's hard to find socks small enough to fit into the fuse slots. besides, socks don't seem to conduct well.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 06-29-2004, 04:15 PM
fast924S's Avatar
Send a message via AIM to fast924S
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 06-29-2004, 04:19 PM
TCMdocs944's Avatar
My socks bleed for that car. It is really so sad.
I have been helping an aquaintance get his 'bargain' 944 going.
I went over the other day because I saw it hadn't moved in a few weeks. He was under the hood 'jumping' various electical point with lamp cord.
He had rigged the one fan (other sitting in the dirt) by jumping a dangling relay at the drivers footwell.
The front hoses were being kept in place with shoestrings (I offered zip ties)
Lamp cord was everywhere....holding this and that together..
loose and missing bolts everywhere.....
What can you say to someone like that?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 06-29-2004, 04:31 PM
Haha, brilliant But still, it's just proof of what the guys at Porsche do when they design and develop cars. The things just keep going, even if you bodge it together with a set of socks. I also found some things that would 100% sure stop a lot of the other cars around to grinding halt, but somehow not the old 951. Even a completly busted rotor that damaged the distribution cap severly was no reason to stop going strong for miles and miles without the driver noticing. Only after doing a simple 'tune-up' i noticed the complete ignition system needed to be replaced (spraks, rotor, distributor and even the wires). Also, it seems that completly rusted starter motors can still crank a 951 to live without a glitch. After getting a new one, the thing still starts as nice as it always did, but somehow the crunchy noise is gone
Fact is: great cars, clever engineering, robust materials = nightmare for amateur mech... (or what some refer to as a GREAT car).
Old 06-29-2004, 04:32 PM
Don 944 LA's Avatar
Did you ask him what brand and style of socks would he like installed.. and should you replace the existing socks ( if they are causing a "serious" problem of course )
Ohhhhhhh, chompin at the bit to hear what this episode of " Sock Man " has instore..
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 06-29-2004, 07:30 PM
Roger Hall's Avatar
my car is broken but dont fix it hehehehe
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 06-29-2004, 07:37 PM
Blackfoot's Avatar
Mike, how long would you guess it would take to determine where there is a current drain in a 928? This drain is only an issue when the car is NOT running, just sitting draining the battery. Are there many things that could be draining juice, or just a handfull?
_______________________
Cars
Old 06-29-2004, 07:39 PM
AFJuvat's Avatar
First thing to find out is how much current is getting pulled while the car is sitting there - it should be fractions of an amp. Anything more than that, and it can get tedious to check - my comments about 3 - 4 kilometers of wiring in the car was not put in there for humorous effect.
I would start witht he unfused circuits first - alternator, starter, and ignition, and then work your way up from there. Depending on how much is getting pulled from the battery, you can judge which circuits to check first - if it is less than 5 amps, you start with the 5 and 8 amp curcuits.
any 928 electrical problem can be a bigger to track
AFJuvat
Old 06-29-2004, 07:48 PM
SoCal Driver's Avatar
Bugger. You misspelled the 'u'. Looked like an 'i'.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-29-2004, 09:57 PM
Texas944's Avatar
could be he meant a bigger bugger..??
Brett, Dallas, Texas (Originally from Sydney, Australia)
1986 944, Zermatt Silver / Black Leather
1994 Full size Blazer, Midnight Blue
1989 IROC, Arrest-me-Red
1966 Corvette Roadster 427 4spd, Silver / Black
DRIVE THEM LIKE YOU JUST STOLE THEM!
Old 06-29-2004, 11:09 PM
vott does ziss do?
ronin's Avatar
qwertyuiop
Old 06-30-2004, 01:15 AM
vott does ziss do?
ronin's Avatar
you don't. you take them out back and shoot them
Old 06-30-2004, 01:16 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I'm always partial to having a couple of my buddies from the APLL (Abused Porsche Liberation League) free them of their car and then take 'em into a back alley somewhere for a lesson in respect from some black rubber hoses and socks filled with gravel.
Black Cars Matter
Old 06-30-2004, 06:52 AM
TCMdocs944's Avatar
You see....
I still hope to buy that car (or AFJ's 928 nightmare) for a song.
I just hope it isn't too messed up by that time.
Yes, I am a glutton for punishment.
Old 06-30-2004, 11:15 AM
nige944's Avatar
AF,
They have some spare parts on Ebay for you
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=10408&item=2481502742&rd=1&ssPageName=WDVW
Nige.
89 944 Turbo 115k miles, Stock
96 Range Rover 4.0 SE 130k miles.
84 944 170k miles, FR Wilk Chip, Sold.
"Don't listen to me, I dont know what i'm talking about"
Old 06-30-2004, 02:28 PM
You see....
heh, hmm,... and I was about to ask about AF's 928. I guess that answers that question.
Old 06-30-2004, 03:49 PM
AFJuvat's Avatar
It is for sale - send in your offers
Just readjusted the timing belt today.
Has a few small oil leaks, tranny leaks, ac not working all that well, interior could use some recovering and some parts.
AFJuvat
Old 06-30-2004, 04:33 PM
TCMdocs944's Avatar
$1000 - Pick it up on sunday!
(probably won't even cover your repairs!)
Old 06-30-2004, 07:07 PM
I'll buy it just to liberate it - for a thousand bucks fine!
Black Cars Matter
Old 06-30-2004, 07:51 PM
