MPG Gauge in 84 NA
What does this really tell me......?????
Old 07-08-2004, 07:14 AM
Burn the fire.
Brando's Avatar
Your DME works??!!
I dunno. was never accurate for me...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 07-08-2004, 07:37 AM
Stan944's Avatar
I once thought it was a direct measure of fuel consumption. Somebody explained to me that it actually measures the air flow to the engine, so it can be off if the air/fuel ratio is off.
1983 red Porsche 944
Old 07-08-2004, 08:00 AM
But.....the air/fuel ratio is set in the DME....correct??????
Old 07-08-2004, 08:33 AM
winter-hater club member
nynor's Avatar
mine worked up until recently. basically, as far as i can tell, it shows your fuel consumption in MPG at a given moment.
i tested this on a long trip to modesto, about 800 miles. while cruising, it sat at about 33 MPG, which turned out to be within 2 MPG when compared with the miles driven and the amount of fuel consumed by the vehicle at the pump.
but don't quote me: i am probably talking out my arse...
"COOL PRIUS!" - Nobody Ever
Old 07-08-2004, 08:39 AM
Stan944's Avatar
yes, but the DME sets the amount of fuel INTENDED. This may not be the actual amount of fuel if the fuel system is not perfectly OK. Also the air flow is measured right after the air filter. If there is an air leak after the air-flow meter, more air will mean different amount of miles per gal of fuel!
But if everything works fine, I think it should be accurate.
Old 07-08-2004, 08:44 AM
TCMdocs944's Avatar
The owners manual says..
under 2000 rpms it shows mpg (bottom # ?)
over 2000 rpms it shows gallons per hour (top # ?)
I just found that out after the PO sent me the owners manual that came with the car. (1.5years after purchase)
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 07-08-2004, 10:29 AM
Don 944 LA's Avatar
Oh, you mean that thing that just flips back and forth...
I thought it was bouncing to the misic..
Does it actually do something ??
Don
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 07-08-2004, 09:12 PM
I'm off the hook.....
Don
This from the guy who has everyone flipping back and forth every time we see his ID.
Old 07-09-2004, 07:14 AM
Ornery Bastard
Uh, it should be that under 20kph it show gallons per hour and over 20 kph it shows miles per gallon. GPH are the lighter numbers.
That's from an '87 924S, but the 924S uses the same guage cluster as the early 944.
The way the guage works: It reads the injector fuel delivery rate from the DME and uses that data directly for the GPH readout below 20kph. The guage also receives input from a hall-effect sensor in the speedometer that will tell it how fast the car is going (this is why there is an electrical connection between the speedometer and the tach). The speed data from the hall-effect sensor is coupled with the DME's injector delivery rate information to compute miles per gallon when the car is above 20kph. If the hall-effect sensor on the speedometer starts to go flaky (fairly common) the the guage will pick up a speed signal only sporatically and will therefore jump between MPG and GPH modes when the car is at speed, which manifests itself as the needle jumping around or just reading really low if there is no signal at all from the hall-effect sensor.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 07-09-2004, 07:32 AM
