had this occur twice during this week.
usually after I've the cars been running and then stopped. when the turning the key, the engine/starter made a "struggling" sound, no both occasions I switched off, as I thought it sounded like a flatish battery. Today when this happened, I'd been out for a long.... drive, parked up, tyo pick something up, tried to start, got the struggling sound, switched off, left for 30sec's. started then the car imediatly stalled, started again, then it was ok. got home and did some basic visual checks, all ok, DME was replaced this/last year (new OEM part), unplugged the relages and refitted, all fuses ok and battery connections ok ! could this be a starter problem, seems only from hot, as I said it was as if the starter could not or did not have enough juice to crank the engine when the fault developed ? cheers A
----------------------------------------------------------- The fear of God is the begining of wisdom <>< NotJustPorsche Subscribe: notjustporsche-subscribe@yahoogroups.com |
Check your ground (earth) wire from the battery to the engine, A corroded\poor connection can cause a hot start issue like you describe
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
AF,
the battery is in the back, and I did have a look at that, seems and feels ok
If the battery is in the back it just makes a marginally corroded wire more of a problem. You still have a ground strap from the battery to the chassis and you still have a ground strap from the chassis to the engine assembly. The engine assembly includes the ground path for the starter.
This is also true for the heavy wire from the battery as it goes directly to the strarter. Look for corrosion inside the large wire at the battery and at the starter.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
"Fatsih" battery?????
cheers
Used & Abused
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
Not looked at the car yet but
I'm gonna replace the battery and engine earth cable, check the starter leads and get a spare DME relay as a start cheers guys
