starter noises/problems : conclusion
well today I set about changing the following
1> battery earth strap (which was in good cond anyway) 2> engine earth strap, which had some surface "virdigris" that was abeetch to change, very tricky to get to the engine bit ! 3> I could not remove the starter has I had hoped, the 2 bolts were rock solid, despite spraying with wd40, however, the contacts on the solonoid looked a bit worse for wear so I removed them and cleaned up the contacts and applied coppa slip compound I did not change the DME relay just kept the new ones as a spare ! I also refit the earth straps cleaned the surfaces and coated with copperslip, so now I need to monitor it and see what happens ! |
| All times are GMT -8. The time now is 11:03 PM. |
