-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   16 Valvers: Hall Sensor question(s) (http://forums.pelicanparts.com/showthread.php?t=177059)
N_Halbert 05-23-2014 07:39 PM
To resurrect an old thread....
So, for those changing the Hall Sensor, How are you doing it? Do you have to remove the Valve cover or some how remove the font cover and loosen the back shroud so you can get the clearance to remove the top Alan head?
I could back out the top one but it jammed up against the valve cover before it had fully disengaged.
Eric_Oz_S2 05-23-2014 11:12 PM
You just need to remove the valve cover
