Every now and again after starting my 85.5 944, the tach doesn't function. Sometime after several minutes of driving it begins to work and other times not until the car is started again. I'm sure this may be a 'contact' issue but I cannot locate anyplace in the engine compartment the tach sensor is connected. Of course it could be the guage but thought to start here. Help is appreciated.
85.5 Porsche 944 NA, 2.7 liter motor, Guards Red, 155k miles |
The tach is driven with a signal from the DME.
It's probably the gauge, unless there is a broken wire from the dme to the tach. gb
Good luck, George Beuselinck |
Tap the istrument cluster glass lightly after start-up..the Tach should start to indicate.
85.5 944na Automatic V-65 Magna 94 Impala SS |
Cebu...pure freakin genious! A slight tap and it works everytime...
Any real way to fix it? Possible to lube the speedo?
1985.5 Porsche 944 |
