AllPorsche944's Avatar
Porsche Crest Engine Removal Question..And Yes I did do a search!
I am curious about the following: I removed the engine out of a 78 924 from the top...I am going to be removing the engine from my 88na but I hear most do it from the bottom: Any thoughts on the following:
1. Leave Bellhousing in car and remove from top leaving behind clutch assembly?
2. Remove from bottom?
3. Remove from top and possibly in two sections (Head then Block?)
Anywho...curious on some feedback...Thanks!
88 944na = Azure Blue
New Rebuilt Race Engine (@190 HP)
Lindsey Racing Fuel System
MSD Ingnition System
Zimmerman XDrilled Frt/Rear
BB Headers & Cat Back Exhaust
Mass Flow Air w/ Ingen Technology
Nology Pro Fire Wires & Coil
Millie Cup Wheels and Kuma's
Old 08-25-2004, 08:07 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
why couldn't you just cherry-pick it out of the top like any other motor?
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 08-25-2004, 08:27 PM
MAK...good question, I agree with you but everywhere I look such as Haynes and the factory manuals they all say take it out from the bottom...seems like a pain to me...just as easy to take it from the top I would guess...
Old 08-25-2004, 08:33 PM
adida(r 944)'s Avatar
when i did my engine swap i pulled the bad engine from the bottom w/bellhousing and clutch assembly. what a PITA took me forever (bout every sat and sun of every week for 7 months)... when i put in a good engine i decided to do it differently borrowed a engine picker from my brother in law and tossed the entire engine in through the top and it took way less time (In and running in 6 days to be exact). also had the bell housing and clutch on and the radiator out when i went from the top. of course it helps when you got the proper tools: jack stands, pry bars, wrenches, cemented shop floor (i think the dirt floor slowed me down to much on the removal, prolly could of done it in same amount of time as reinstal) and it helps when you dont have someone swipping tools from you all the time too. well anyways i think its easier to go from top. less susspension crap to go through.
85/1 944 project/restore/upgrade in process finnaly:
Bursch headers and cat delete pipe. fiberwerks front bumper and rear wing
cant spell forgive my "hukt on Fonix" it workt gud four mi
in the process of buying a car and a half garage with a detached house and fenced in yard
03 Eclipse GS
Old 08-25-2004, 09:09 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
OK.
remove it from the bottom.
believe me.
Sure, pulling it out the top doesn't take too long.
But, I'm currently (I'm just taking a break, I mean RIGHT NOW) trying to get the fukker back into the top. uh. do it from the bottom... you'll be happier that way
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 08-25-2004, 09:12 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Turbos are MUCH MUCH easier from the bottom.......
but on the NA's either way is fine... (but still easier from below)
The problem when you pull it out from the top is that you need to pull the engine quite a bit forward to get the torque tube out............. and the oil pan gets in the way (hits the cross member)..
SO remove four bolts (crossmember) and the entire engine drops. The trick is the car has to be at least 24 inches high to slide the engine out from underneath.
Now there is a guy up here that removed the entire engine, tranny drive shaft and suspension............and LIFTED the entire body off the car. NOW THAT WAS NEAT!
but like it was mentioned pull the rad, and remove as much as you can from the top and you can get it out.....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 08-25-2004, 09:40 PM
what about the crossmember? Seems like that is in the way...that adds a few morebolts...
Old 08-25-2004, 09:58 PM
ilikemy944's Avatar
Yeah, you gotta pull the crossmember, and steering rack...
Got my engine in
Brad Tompkins
Old 08-25-2004, 10:23 PM
Parrothead member
VINMAN's Avatar
I pulled 2 motors out from the top, wasnt realy much of a problem with either one. the main prob is the tourqe tube ,but i pulled the transaxle first on the second motor and slid the tube back that made it a hell of alot easier.
Vinny
Old 08-26-2004, 04:21 AM
jm951's Avatar
It can be done either way, but I think the turbo is probably easier out the bottom. The key to taking it out the top is to remove the tranny and slide the t tube back clear of the bellhousing. Also remove the radiator and fans for some more maneuvering room. Remember to scribe the hood hinges to they realign properly. Good luck, this isn't hard, just time consuming.
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 08-26-2004, 06:45 AM
Hmmm...removing the tranny to take from the top seems like a lot of extra steps? Maybe eaiser to take from the bottom...a lot less removals?
Old 08-26-2004, 08:37 AM
Parrothead member
VINMAN's Avatar
either way, top or bottom, its much easier with the tourqe tube out of the way
Vinny
Old 08-26-2004, 09:48 AM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
tranny is about an hour and a half to drop, I took mine out the top and disconnected the bellhousing first, I would do it this way agian, much simpiler than out the bottom if you ask me...
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 08-26-2004, 02:40 PM
Couple of commetns and questions on my part...
Why would you pull the engine, or ANY major component removal/install from the engine bay without pulling the radiator first? This is a VERY delicate and important part of your car. It should ALWAYS be the first thing you take out when you pull a motor...
When I pull motors, I pull them from the top with the transmission attached. I've pulled more 13b setups than I have fingers and toes and eyeballs and possibly teeth too, and several 7m-GTE/GE setups, and one 2jz-GTE w/V161 (****ing 6spd is HUGE)...what's the difference between the torque-tube on the 944 and a tranny pull/with on any other?
Why do so many parts of the 944 sound like titles to cheap porn (torgque tube)?
Old 08-26-2004, 03:22 PM
ilikemy944's Avatar
Mak - the torque tube sticks into the bellhousing like 6"
so if you pull it with the bellhousing attached, you have to pull the engine forward enough to clear it... this is where you run into issues... before the engine hits things and stops going forward, you have another 1" left inside the bellhousing.
Its hard to get around it, but you can...
Oh, and I didn't name these things
Brad Tompkins
Old 08-26-2004, 08:22 PM
Crippler's Avatar
I have removed my engine from both the top and bottom and found removing it from the bottom much easier.
1984 - Porsche 944
1994 Grand Cherokee
6inch Lift, 33" TSL'S
Old 08-26-2004, 08:50 PM
