How critical is this.....
I was just underneath my car about to lossen the allen for the coupler from the torque tube to the trany, when I marked the trany shaft it suddenly occured to me that this part was not going to be on the new trany so i would have no referance mark when putting the car back together with the new trany.....so how critical is it that the coupler is on the right spline of the new tranny shaft.....????
1985/late 944
Old 08-25-2004, 12:04 PM
I fail to see why it would make a difference. The coupler is balanced, the torque tube shaft is balanced and the clutch disk is balanced. There is nothing else on the torque tube side that can be aligned.
Nigel
'87 924S 5sp
Slowly recovering from a warped head
Old 08-25-2004, 12:26 PM
jm951's Avatar
It's not critical at all. Just make sure when you reinstall the new tranny to run the bolt back down and properly torque it.
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 08-25-2004, 12:44 PM
Proper torque?? You must think I'm a CERTIFIED tech! Just kidding, Thanks for the help hopefully ill have it all done by Saturday night!!!!!!!
1985/late 944
Old 08-25-2004, 01:34 PM
jm951's Avatar
You don't have to be a certified tech to get torqued!!!!
Old 08-25-2004, 01:35 PM
I GOT THE OLD TRANNY OUT!!!!!!!!!
WOW......
1985/late 944
Old 08-26-2004, 07:26 PM
someone ansewer my question now
early '85 944 -project car, sort of works.
Old 08-26-2004, 07:32 PM
And what question would that be???
gb
Good luck, George Beuselinck
Old 08-27-2004, 08:48 AM
Okay for some reason (cost?) the PO put two 5/16 grade 2 or 3 bolts to hold the trany to the tranny mount...of course the bent.....does any one know the proper part that is supposed to reside there, the dealer is closed and it doesnt seem like i can find a grade 5 or 8 bolt that long........I would really like to get this thing running tongiht...any help??
1985/late 944
Old 08-28-2004, 10:45 AM
Thank god Porsche built tractors.....I went and got two grade 8 5/16 bolts that where 4.5in long from the Tractor Supply Company and mounted my tranny, it all worked out great except that the torques for the cvs kept stripping, im going to replace them with new allen head bolts here soon but its done i finished.....in the morning im going to take it around the block illeagaly of course, no plates no inssurance, but eh at least ill know if everything works!!!!
1985/late 944
Old 08-31-2004, 09:41 PM
