-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   strange ECU mod (http://forums.pelicanparts.com/showthread.php?t=183902)
nynor 09-22-2004 03:57 PM
strange ECU mod
has anyone seen one of these before?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=72205&item=7923125 074&rd=1
not that i am going to get one, mind you... 20HP? yeah, right.
bluebullet 09-22-2004 04:16 PM
its a fancy box with a resistor in it....BS
fast924S 09-22-2004 08:05 PM
yup Bluebullet has got the right answere, All it does is change the resistense reading of the intake air temp sensor this tricking the ECU to thinking its very cold out, wich adds more fuel and plays with the timming. You might get 5-8hp but 20 NOOO WAY
nynor 09-22-2004 09:58 PM
er... 5-8 HP? how is that?
flangermog 09-23-2004 07:59 AM
Basic Laymans explanation as I understand it:
Cars can be tuned to run economically and save fuel or to run a little richer (more fuel) to gain a little performance. This does result in the engine not running so smoothly - hence race car engines are quite lumpy at idle. The added fuel will make a more volatile explosion within the engines cylinder and the timing is adjusted accordingly to allow that explosion to take place.
In an instance where ONLY more fuel is added to the mixture and the timing is not adjusted this means you will just lose the extra fuel through your exhaust and not make any use of it - hence the timing is altered to allow more fuel to enter the chamber before the spark ignites it.
Too much fuel will result in no air being present for the explosion to detonate which is where the term 'flooding' the engine comes from - quit simply the combustion chamber is full of liquid and so cannot ignite. Race cars idle on the verge of flooding because more air can get in when the car is moving due to the increased pressure.
nynor 09-23-2004 08:05 AM
i see...
i have to ask now: is this worth $30 and will it work on a 944?
nynor 09-23-2004 12:26 PM
unhook the O2 sensor?
flangermog 09-24-2004 03:05 AM
except for the fuel bills...
Porsche944 09-28-2004 07:02 AM
This "device" is designed to connect to the "feature plug" on the DME harness.
Mr. Wilk should be able to shed some more light on this, but the basic idea is to change which maps the DME uses. One example is altitude compensation.
When you go above about 4500 ft, the altitude switch closes and "tells" the DME to change the mapping.
Again, Mr. Wilk is probably your best source for info.
CJFusco 09-28-2004 07:04 AM
or you could just buy the FRWilk PowerProm and get REAL HP increase and the knowledge you DIDN'T fall for fool's gold
nynor 09-28-2004 02:10 PM
well, i have tried to email mr wilk (hint hint) about changing my AFM and DME to an 86, but haven't heard back.
that said, i am not hooking that thing to my car. i was just curious as to what the hell it could do. i PROMISE.
