winter-hater club member
nynor's Avatar
strange ECU mod
has anyone seen one of these before?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=72205&item=7923125074&rd=1
not that i am going to get one, mind you... 20HP? yeah, right.
"COOL PRIUS!" - Nobody Ever
Old 09-22-2004, 03:57 PM
Send a message via AIM to bluebullet
its a fancy box with a resistor in it....BS
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 09-22-2004, 04:16 PM
fast924S's Avatar
Send a message via AIM to fast924S
yup Bluebullet has got the right answere, All it does is change the resistense reading of the intake air temp sensor this tricking the ECU to thinking its very cold out, wich adds more fuel and plays with the timming. You might get 5-8hp but 20 NOOO WAY
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 09-22-2004, 08:05 PM
nynor's Avatar
er... 5-8 HP? how is that?
Old 09-22-2004, 09:58 PM
flangermog's Avatar
Basic Laymans explanation as I understand it:
Cars can be tuned to run economically and save fuel or to run a little richer (more fuel) to gain a little performance. This does result in the engine not running so smoothly - hence race car engines are quite lumpy at idle. The added fuel will make a more volatile explosion within the engines cylinder and the timing is adjusted accordingly to allow that explosion to take place.
In an instance where ONLY more fuel is added to the mixture and the timing is not adjusted this means you will just lose the extra fuel through your exhaust and not make any use of it - hence the timing is altered to allow more fuel to enter the chamber before the spark ignites it.
Too much fuel will result in no air being present for the explosion to detonate which is where the term 'flooding' the engine comes from - quit simply the combustion chamber is full of liquid and so cannot ignite. Race cars idle on the verge of flooding because more air can get in when the car is moving due to the increased pressure.
(x)'89 944 S2 Cabriolet (Guards Orange) :
( )'90 944 S2 (Maraschino Dead!) :
( )'89 Audi 90 Quattro 2.3 20V :
( )'92 Renault Clio 1.4 :
Old 09-23-2004, 07:59 AM
nynor's Avatar
i see...
i have to ask now: is this worth $30 and will it work on a 944?
Old 09-23-2004, 08:05 AM
nynor's Avatar
unhook the O2 sensor?
Old 09-23-2004, 12:26 PM
flangermog's Avatar
except for the fuel bills...
Old 09-24-2004, 03:05 AM
This "device" is designed to connect to the "feature plug" on the DME harness.
Mr. Wilk should be able to shed some more light on this, but the basic idea is to change which maps the DME uses. One example is altitude compensation.
When you go above about 4500 ft, the altitude switch closes and "tells" the DME to change the mapping.
Again, Mr. Wilk is probably your best source for info.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 09-28-2004, 07:02 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
or you could just buy the FRWilk PowerProm and get REAL HP increase and the knowledge you DIDN'T fall for fool's gold
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 09-28-2004, 07:04 AM
nynor's Avatar
well, i have tried to email mr wilk (hint hint) about changing my AFM and DME to an 86, but haven't heard back.
that said, i am not hooking that thing to my car. i was just curious as to what the hell it could do. i PROMISE.
Old 09-28-2004, 02:10 PM
