Sounds like its time for me to replace my rear 4 X 6 speakers. Im going to install a plate and install 6.5s in place for them. These car speakers are wired weird....the front right and rear right connected and the same for the left. If i install 6.5s in the rear i dont think only one channel will be sufficiant for both the front and the rear speakers on each side. If i unplug the speaker wire from the rear speakers would the power that they are draining be used by the fronts so I could then run some fresh wires from my rear channel to my new speakers.
1986 951 1983 944 |
Please ask your question in the form of a question.
http://forums.pelicanparts.com/uploa...1093905626.jpg the "baby" that comes first... |
Cars & Coffee Killer
Yes, assuming you have a four-channel head unit and you are only using two of those channels to run all four speakers.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
just run new wiring, it not too hard
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
I"m about to add some more speakers to have 6 channels (4 front, 2 rear) and the headunit should handle that. If not, I may get a crossover amp and then just run the sub with the preamp out. You should be fine with your wiring unless you go blasting music constantly.
Ryan '84 944 moneysucker edition (SFR, Corbeaus, etc.) '02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's |
You have a 6-channel headunit? I've never heard of a six channel headunit. Hell, most surround sound units (for cars or home) only have 5. What headunit are you using?
The way the 944 is wired one channel runs 4 speakers so he will add 2 more speakers and have 6. I already have a 12 inch sub in my car and no Its not rattling my car as I have my amp turned down low for mostly rock musics. It sounds really good I just want to add the 6.5s or 6X9s for mids.
1986 951 1983 944 |
Would there be room for 6X9s where the rear 4X6s are?
1986 951 1983 944 |
The way the STOCK car is wired there are only TWO channels. In base 944's there's two speakers on each channel. In teh 10 speaker cars there's 5 on each channel...but there's ONLY TWO CHANNELS. (may be differnt on later models but it's like this in mine. Pre-86 cars may be a single channel as there's only 3 speakers in the car (I think))... Speakers are NOT channels. "They're components", or (duh) "speakers". The number of channels is dependant on the headunit and means of recording, NOT the number of speakers. As precise as a 4-channel recording is, I can't even see the need in a 6-channel headunit.
I want to add the 6x9s and then replace my 4x6s in the front with another pair because i hate the stock system.
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
