icu unit
is there any way of testing the icu unit as i have done some voltage tests at the coil and they seem wrong in that the voltage at terminal 1 is around 4 volts and the voltage at terminal 15 is 9.5 volts the haynes manual says that the icu unit is u/s if high volts at number 1 and battery u/s if low volts at 15 but it is a new battery
The car is a 1983 924
1982 Porsche 924 |
icu unit?
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
idle control unit??????/ icu????/ need more info
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
icu: Ignition control unit
Check terminal 4 of icu between it and ground - you should read battery voltage. Failing that, your coil or ballast resistors are faulty. IF that all tests good, check voltage between terminal 1 of coil and ground (with ignition on) it should read 2.0 volts max. If the voltage is incorrect, your icu is faulty. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
