Tachometer compatibility
Will a 924S tach work in an 83' 944? Only difference I know of is the shift light, but will it work properly otherwise?
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 01-04-2005, 08:20 AM
Nope, different part numbers, should not work.
gb
Good luck, George Beuselinck
Old 01-05-2005, 03:06 AM
That was what I had seen too, but I thought maybe that was just for the shift indicator... Thanks. Do you have 83' tachs for sale?
Old 01-05-2005, 09:21 AM
I replaced all the gauges in my 944 with 924S gauges ( i like the white letters better than the yellow). It worked out fine, no fuel economy gauge but that was annoying anyway. I have 2 83 944 tachs F/S though if you want send me a PM.
1983 944 Copenhagen Blue
MODS: ENGINE: Firebraid 9mm plugwires. Weltmeister Throttle Cam, Dansk exhaust. lo-temp thermostat & fan switch, aluminum radiator. SUSPENSION: H&R 250lb springs, KYB GR-2 struts(front) Bilstien Shocks(rear), Racing Dynamics strut bar, APPEARANCE: 15" Phone Dial wheels, a-pillar w/ VDO H2O and volts gauges.
1987 944-S Montego Black
-needs your help
Old 01-05-2005, 05:08 PM
Glad to hear it, thanks. I'll keep that in mind if this doesn't work out.
Old 01-05-2005, 07:43 PM
