Early 944 wheels and offset
I thought I was getting ahold of this issue, looking for "early offset" replacement wheels. Then I saw 951 RacerX's page on stock wheels. It says 15x7 cookie cutters use a spacer in the rear. Fuchs 15x7/15x8 show no spacer in the rear. I have those size Fuchs, but there is a spacer in the rear. Is that OK or did the previous owner replace cookie cutters with Fuchs but leave the spacer on? Do I need 23mm offset wheels or is there more to it than that?
Thanks, Chuck
1985 (early) 944
Old 01-17-2005, 07:05 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
I have the factory rear spacer with my fuchs, it just makes the rear ones fill out the wheel wells a little better, I like it alot! Not a problem at all. I think fuchs came from the factory with that rear spacer, at least both of my cars had them.....
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 01-17-2005, 07:48 PM
Warwood's Avatar
Every early 944 I have ever owned had those spacers. I haven't checked my 85/2 yet, but I believe that when they started using the cast alloy trailing arms they resolved this issue which goes back to the 924 M471 days.
Revis Rose
'84 944 NSRC
Old 01-17-2005, 09:18 PM
tifosiman's Avatar
85.5 and onward 944's did not have the spacer on the rear, prior years did have it standard.
1985.5 944 Club Sport
My P-caronline Profile
"A good time to keep your mouth shut is when you're in deep water. "--
Sidney Goff
Old 01-18-2005, 07:17 AM
