Scary gas problem...
So, I filled my tank today($36.32) and it started to smell like gas...really bad... inside the car, outside the car. Drove around all day like this, decided to see what the problem was -
Took the rear carpet out, took off the little white odor absorber thing... and the thing was full of gas.. it didn't go all the way up to the wires, but jesus, I was scared to drive anymore.. What could the problem be? |
a leak.
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
I would replace the rubber gasket sealing the fuel level sending unit to the tank first. They dry out, and crack over time. It's a really simple fix.
Brent Early85 944 LM6Y Paint Code |
Is that whole big black "cap" thing the sending unit?
On an early car, yes. Not sure on a later car though........... I would wait until someone with a later car posts just to be sure.
I just noticed that you have a late car, and I have zero experience with them. I'm sure someone will be happy to help though.
check the hoses and where the sending unit screws in for leaks.
Certified Rennwerker
Filler neck leaks. Next fill don't top it off and see if you get fumes.
PCA " I've been everywhere, done everything......just can't remember any of it!"
Well the car always smells a little bit like gas, but now it's ridiculous. Is it safe to be driving around with essentially a puddle of gas inside my car?
Only way I can see gas soaking the rear carpet is the filler neck seal is shot. The tank level sender is below the carpet on top of tank.
Just don't smoke or flick your Bic!
With my luck, someone is going to flick a ciggarette out their window, it is going to somehow get inside my car, and I'm going to explode
Heavy fumes will be the real danger. Get a spark and up you go. Given our cars' bad wiring this would not be out of the question in just normal operation. |
What little white odor absorber thing?
Sounds like something a PO put in the car. Might have holes in the top of the tank from a stereo installation.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Will work for parts
in late 944's there is a nomex square over the sending unit
'88 944 240,100 miles -race car '05 Boxster 110,000 - Daily Driver '74 911 Targa - long term project |
nomex is fire retardant, not fire proof.
Also, what is the part number for the gasket I need? Last edited by Clowd; 02-07-2005 at 09:57 AM.. |
i just wanted to clarify that the nomex pad won't protect you forever.
