-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Stub axles (http://forums.pelicanparts.com/showthread.php?t=205966)
Low 02-11-2005 03:34 PM
Stub axles
Well ive started the process of replacing the half shafts and bearings, and quite frankly have hit a wall ;) . Hayes says to torque the castle nut down to 340 fl/lbs... well ive established that there must be a crush sleve. My question is does one have to replace these, or can you just put new bearings slide it back in. If so how much torque would it need? Any help would be greatly appreciated.
Britwrench 02-11-2005 04:04 PM
There isn't a crush sleeve, only a spacer. Make sure you assemble everything correctly. You will need the inner and outer seal and the outer o-ring. Tighten the hub nut to the correct torque as you posted.
Low 02-12-2005 01:28 AM
...so there isnt ehh :D thats what i get for listening to a chevy mechanic. ;) And yes i have all the seals i just wanted to make sure i had it right the first time. Thanx for the help.
Britwrench 02-12-2005 08:46 AM
When working on these cars you should have a workshop manual.
SoCal Driver 02-12-2005 11:48 AM
Also the spacers have to go back onto the sub axles in a certain direction/order or it doesn't tighten correctly.
