Ken, show your class and style and make sure you always play well with others. You may need thier help someday.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
hey i wasn't being mean, just joking and poking a little fun, that's all
'87 924S '88 Saab 900 SPG Turbo (25psi!) |
i am glad to get this conversation going again though because with gas prices so high, i don't want people paying extra and not getting anything out of it. now if it actually helps(higher compression vehicles, forced induction, etc), go for it! i used high octane with iso in my saab because it really boosted performance. It just bothers me that some people think that even though their car calls for low or mid grade, that somehow high grade will give them better results. that's like, being tricked by the gas companies! i mean, they charge us enough already, we don't have to fall into their, do you want "Low" grade or "Performance/Ultra/Premium" trap.
Keith 1986 Porsche 951 |
German Aut0haus
When i had my old '65 Impala i had no choice but to use 92 or 93. Anything less and it would ping. Jumping up to race gas would do nothing for it. In theory, and actual use.
'90 964 C4 |
German Aut0haus
'90 964 C4 |
B. Elliott, i know octane is not about increasing performance, i'm saying that in my saab, because it didn't ping, it allowed me to have increased performance(knock sensor). See??? i already posted that it's not about performance, and that the higher the octane rating, the less likely the fuel mix will preignite. i realize that the higher the compression, the more likely the fuel mix will preignite. just use whatever the manufacturer says to use, of course using the correct units. technically, the higher octane fuel produces less energy, but not significantly or noticably... diesel, with an octane of what..... 20's(or 40's?? i don't remember) has more energy than gasoline but is very easy to pre-ignite, that's why diesel engines don't use spark plugs, it just ignites itself as pressurized air enters the chamber- too high an octane and the engine may not run, too low, ping - no increase of performance.
'87 924S '88 Saab 900 SPG Turbo (25psi!) Last edited by Ken99287; 09-15-2006 at 09:04 PM.. |
Ornery Bastard
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
M |
to reduce pinging, i think you can.... retard the timing?? i think... or is it the other way around??? you can usually do a slight adjustment on the distributor... on some cars anyways.
German Aut0haus
Driving around town at steady/low rpms will cause quite a bit of buildup. Sometimes going WOT is actually good preventative maintenance.
'90 964 C4 |
