putting turbo/S2 valence rear valence on NA
I picked up a nice rear turbo valence for my car last night. I am trying to figure out if it mounts up to something that is already on the back of the car or if i am going to have to do some drilling.
1983 944 Copenhagen Blue
MODS: ENGINE: Firebraid 9mm plugwires. Weltmeister Throttle Cam, Dansk exhaust. lo-temp thermostat & fan switch, aluminum radiator. SUSPENSION: H&R 250lb springs, KYB GR-2 struts(front) Bilstien Shocks(rear), Racing Dynamics strut bar, APPEARANCE: 15" Phone Dial wheels, a-pillar w/ VDO H2O and volts gauges.
1987 944-S Montego Black
-needs your help
Old 03-02-2005, 10:27 AM
tifosiman's Avatar
Re: putting turbo/S2 valence rear valence on NA
Since your car is an 83, there are no mount holes pre-existing for it to mount to. The 85.5 and later cars have the 5 holes pre-existing under the car (because it is the same chassis as the turbos). However, even on those cars you need to drill the 2 holes on each quarter panel just at the line for the stone-guard material.
It will help you if you use a floor jack to hold the large piece up to psuedo-mount it, and mark the holes you need to make. The smaller piece on the drivers side can be held by hand and the holes marked.
Good luck!
1985.5 944 Club Sport
My P-caronline Profile
"A good time to keep your mouth shut is when you're in deep water. "--
Sidney Goff
Old 03-02-2005, 10:58 AM
That Guy
Techno Duck's Avatar
When drilling the holes into the sides of each fender, make sure you measure (in this case line up and mark) twice and drill once. Needless to say i drilled 2 extra times on my drivers fender and once extra on the passenger. Nothing bondo and some touchup paint didnt fix...but avoid having to do that all together.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 03-02-2005, 01:05 PM
Z-man's Avatar
Excellence magazine did an article on adding a turbo rear valence to an n/a. It's not that difficult to do, and the article was very detailed.
-Z.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 03-02-2005, 01:31 PM
tifosiman's Avatar
Shhhhh.
http://members.rennlist.com/tifosiman/page1.jpg
http://members.rennlist.com/tifosiman/page2.jpg
http://members.rennlist.com/tifosiman/page3.jpg
http://members.rennlist.com/tifosiman/page4.jpg
Note that it really pertains to post 85.5 cars that have the 5 pre-drilled holes. But it should be helpfull nonetheless.
These links will self-destruct in 2 days.
Sidney Goff
Old 03-02-2005, 01:36 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
tifo, i appreciate it greatly, nathan, I am gonna do this eventually, I'll have to see what you do with this... I'm getting the car out tommmorrow!!!
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 03-02-2005, 06:10 PM
aribop's Avatar
You can take a look here also...
http://forums.rennlist.com/rennforums/showthread.php?s=&threadid=115905
'95 993 Monster in the making
'89 S2/Turbo aluminum grill monster: terrorizing another state
Old 03-03-2005, 07:31 PM
