Humming..
This has always happened since I've owned the car, but it's been getting louder and noticeable at lower speeds lately.. at about 35 MPH, regardless of engine speed, there is a medium-high pitched humming sound.. it goes away when I turn the wheel left, but not when I turn the wheel right... wheel bearings?
Old 03-04-2005, 04:08 AM
Parrothead member
VINMAN's Avatar
sounds like the p/s pump, mine did the same thing right before it went kaboom. But yeah ,I'd check the wheel bearings too.
Vinny
Old 03-04-2005, 05:50 AM
Where is the hum from, front or rear, left, right? I had a similar noise that was from my rear wheel bearings, both left and right went south about the same time (within 5,000 miles).
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 03-04-2005, 08:31 AM
Um, it's hard to determine.. for the most part it sounds like it's coming from the rear, but now and again it sounds like front-passenger..
edit: sometimes on the highway it sounds kind of like a V8 exhaust.. if you know what I mean...?
Old 03-04-2005, 02:26 PM
