Valve guide reaming problems/honing
My local, usually very talented machinist is getting his butt kicked by the guides in my 1986 N/A head. He's on the second set of replacement guides after having problems reaming the first set properly.
He says he needs to buy (or have made) .352 and .353 reamers to "step" the reaming to get to the standard .354. These sizes are not readily obtainable and will probably be an arm and a leg to have made.
I don't understand why he's having this problem. He's worked on lots of import vehicles before, including 944's, 911's, etc. and he's getting frustrated too. He says the guides shrink so much when he installs them that he has to do the "step" procedure, otherwise the .354 reamer is cutting too much material, it grabs and ruins the guide.
At this point, I'm considering going with an exchange head, since mine would still serve as a usable core. Any recommendations on companies that offer rebuilt heads (I know 944 Online does this for $495) or might be able to do the reaming (my preference) are appreciated.
Also, any thoughts on honing guides for clearance and/or final surfacing would be good to hear about.
Thanks - Jim
Old 02-22-2007, 06:21 AM
SoCal Driver's Avatar
Call one of the major Porsche head rebuilders. Maybe even Pelican Parts and ask to speak to or get the phone number for whom ever does the work on the 944 heads. They can tell you all about what tooling is needed to do the work.
By the way there are adjustable reamers readily available. Also number drills to rough the guides bore out.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-22-2007, 07:47 AM
Greasy Member
many944s's Avatar
^ +1.
Any time I have installed new valve guides in a 944 head, I have to use a "roughing bit" to enlarge the bore slightly before running the cutting bit in. Usually after 2 passes, the bore can be honed.
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 02-22-2007, 07:54 AM
Good advice and thanks guys, everything else has gone smoothly up to this point. We have great empty highways out here, fun for drivers, but the choices for Porsche repair are non-existant.
Hugh - we lived outside of Pasadena many years ago, but I don't know rebuilders in the area. Any you would recommend?
Nick - thanks, I will hopefully be able to contact you soon about that 9201.
Jim
Old 02-22-2007, 06:31 PM
Greasy Member
many944s's Avatar
Jim,
No problem, I should be getting it back towards the middle of next week. Just let me know when you are ready for it!
-Nick
Old 02-22-2007, 06:56 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
My grandparents and one uncle (and family...know any Denmans?) live in Casper so I've been there many many times. You definitely have some open roads up there....at least in the summer time. You still have to watch out for the wildlife though...seemed to be a lot of that.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-22-2007, 11:36 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Why do the guides need machining out? New guides are not in spec or something? Why does a guide need reamed on a new valve stem?
Getting ready to rework my head and this info has me puzzled.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 02-23-2007, 06:42 AM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
Most valve guides need to be reamed to fit. I am thinking that in the olden days, people would reuse old valves and sometimes they would want to polish the stems slightly undersize and ream the guides for a proper fit. Not sure why this is still done, but it is also possible that the guides themselves cannot be guaranteed to maintain the proper ID when they are pressed into the head, so making them undersize and reaming to fit after installation makes sense.
I am not a machinist, I just know enough to be dangerous.
nate
1988 944... and a bunch of other cars
Old 02-23-2007, 12:13 PM
Back on-line
Razorback - Sorry, don't know any of your family here. They may have seen or heard me talking about highway issues - I do PR for WYDOT in central and eastern Wyoming. Yes, lots of roadkill!
Can anyone reccommend a head rebuilder in the Western U.S.?
Thanks for the responses.
Jim
Old 03-09-2007, 05:47 AM
white944cup's Avatar
toolboy62: you are right about sizing the valve guides.....the factory service manual calls for a .06-.08mm press fit, which is approx. .0024-.0032" press, which is a lot of press on the guide. That is why they also recommend heating up the head and freezing the guides in liquid oxygen before installation. With this much press, the inner diameter of the guides will collapse on installation, which means they need to be reamed afterwards to correct size. The manual recommends using Special Tool 3015, which is probably a step-type reamer.
1988 944 Turbo
Guards Red - Black Leather
Autothority Stage 2 Chip Set
Weltmeister Strut Tower Brace
1984 944 - Sold to rcecale
Old 03-29-2007, 06:27 PM
