Porsche Crest starter problems, I think?
I have a 1984 944 automatic, I just tried to start the car and got nothing but a humming sound when I turned it over. I tried to start it several times, but nothing. I gave it a few minutes and tried again and it started rite up. I just installed a new alternator and battery. I also noticed if I hold it in the on position or crank it over several times it will catch. Again, it doesn't make any noise but a humming sound when I turn it over. Bag ignition switch, perhaps, or bad starter? Thanks in advance for your help!!
Old 04-26-2005, 01:41 PM
Feelin' Solexy
Tishabet's Avatar
My guess is that the armature in your starter is no longer engaging and the whirring you hear is the starter motor spinning without coupling correctly to the flywheel.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 04-26-2005, 02:33 PM
SoCal Driver's Avatar
Concure. Clean the grounds at the chassis and at the engine.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-26-2005, 03:07 PM
