does anyone know if you can bypass or jump out the neutral
start or safety switch. sometimes it does not know if it is in park or neutral and will not start. i can shift it between park and neutral a few times and then it will start.1986 944 |
gear selector 'interlock' switch has a pair of red/black wires that must connect to each other (through the switch) to supply 12 volts to the starter.
interlock switch is mounted to the gear selector bracket.
Tom Early '85 944 |
damn... just posted about that here: http://forums.pelicanparts.com/showthread.php?threadid=228503
well, atleast I think it is about the same thing. and i think carson just answered my question... gear selector interlock switch, ehhh?
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
thanx for the info carsontc the contacts on the switch are worn out new one is on the way from porsche
