whistling sound under acceleration
I've noticed recently that at full throttle at 4-5k rpm my 944 has a bit of a slight whistling noise. Can't tell where it's coming from, and it's not really loud, but its just noticeable and it has started to bug me a little. I never really noticed it before a few days ago. The vacuum line to the fuel pressure regulator/ damper is disconnected at the check valve. Could this do it?
keep the dream alive! 1988 944 NA (purple) |
Well, First things first you should have all your vacuum lines connected, With out it on your screwing up the A/F ratio, Other then that u need to find where its comming from, Is it the enigne? is it bad weather stripping?? ect..
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
