Quick door handle question
Hey guys,
I broke the trigger part of my drivers side door handle off a couple of days ago. I am looking at bidding and hopefully picking up this door handle of Ebay
1. How hard is it to replace the lock and put the one I have in on my current handle?
2. What is this "installation screw" he is talking about? Can I just take it off my current handle?
3. This isn't too much to be paying for the door handle is it?
Thanks,
Nate
'84 944, '05 GTO
Old 08-27-2005, 08:20 PM
SoCal Driver's Avatar
Everything you ever wanted to know:
http://www.pelicanparts.com/techarticles/968_upgrades/968_handles.htm
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-27-2005, 08:22 PM
In addition; you can take the door handles out by removing the retaining screw that is inside the door jamb. Slide the handle forward and pull the back out first. Once the handle is hanging outside the door (tape up around the door handle opening so you don't scratch the paint) you can reach in with a thin blade screw driver and pop the ball socket clip off.
You will need to put the key into the tumblers before you remove the screw from the back side. Remove the tumblers with the key in them. Watch out for the pins as they will want to pop out. I take the tumblers apart and clean everything, relube before re assembly. Be sure to get the same side handle and if possible the same year range -- early or late. You can use the later handle(s) but may have to put your pins in the new tumbler barrel or rearrange the ones in the newer tumbler barrel.
Watch the orientation of the tumbler when reassembling the tumbler into the handle. The lever has to move equally both directions.
Putting the handle back into the door is a bit more challenging. in that you need to pop the fitting back onto the ball, put the handle back into the door and check the linkage adjustment. If you are lucky you may have to take the handle out and adjust the linkage only once.
Old 08-27-2005, 08:33 PM
Wow thanks SoCal, it seems like you are always answering my questions Hopefully I win this auction so I can stop having to open the passanger side door and reaching across to unlock the drivers door... oh so humiliating.
'84 944, '05 GTO
Old 08-27-2005, 08:44 PM
Think the handles on the early 944's are the same as the VW rabits of about the same years.
Like this eBay auction #7994894574
Old 08-27-2005, 10:12 PM
I am going to have to do this job too eventually...Mine is slowly but surely getting harder to open on the drivers side...
89 Porsche 944
Owner: AutoFreeFinders.com Online Auto Mall
Old 08-28-2005, 10:21 AM
May have the black plastic snap stretching out. Or it just needs a good lube.
Old 08-28-2005, 06:38 PM
