ae1969's Avatar
Send a message via ICQ to ae1969
Lindsey Racing Intake - Review
I picked one of these up for my B-Day for my 944 Turbo.
I must say I was quite impressed with the workmanship on this piece. I own a few LR products and this one is definitely top notch.
One of the main reasons I bought this intake was to equalize the flow over the 4 runners. THe 944 turbo under boost applications historically will lean out #4 first.
I have been testing some of the extremes of my set up..........and at the same time have roasted 2 head gaskets over the summer in the name of science.
My current setup
- Vitesse Stage 2 (t04e), 240 CFM head, 55 lb injectors, Smt6, LR fuel rail, SFR 3" testpipe/Cat back, AVC-R etc.... etc. etc..
1st Tests
91 Octane at over +21 psi - Car runs very strong. EGT's would occasionally peak excessively high at 1500+F on #4 runner and she finally blew the gasket. THe AFR was set at this point at 12.0 at 3.5Krpm to redline...............
2nd Tests
91 and 94 Octane at over +22 psi - Car runs very strong. EGTs still would rise on #4. ~1450F. The AFR was set to run 10.5 at 3.5Krpm to redline. She finally blew.
The first 2 headgaskets showed serious detonation on #4. The ring was pounded in every segment. 1,2 and 3 were in very good shape with the occasional dent.
Install Lindsey racing INtake for the third test.
3rd Test (only the first week and hopefully the results stay true)
94 Octane at over +21 psi and setup like test #2.
- idle smoothed out (but that was probably an intake leak I was chasing)
- AFR that was previously at 10.5 to redline...... was now going of the scale RICH on #4. The 4th runner was now getting less flow (equalized).
The intake definitely addresses one of the short comings of the stock intake.
I will finally re-tune and lean it out to optimize power and get her on the dyno.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-09-2005, 02:22 PM
will944's Avatar
Send a message via AIM to will944
Thanks for the write-up. Good to know the LR intake is a quality built product, and can help even a car that is virtually stock...like mine.
Keep us updated.
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 09-09-2005, 02:46 PM
fast924S's Avatar
Send a message via AIM to fast924S
Wow sweet test you have run. I bet that is one killer 951 at 21 and 22 psi thats crazy boooooost. I had no idea you had a setup like that. ANyway keep up the good work and keep us posted.
P.S HAv you thought about upgrading your head gasket? I know Guru Racing makes a really nice one that wont burn up in high booost
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 09-09-2005, 06:21 PM
ae1969's Avatar
I ran an MLS gasket a couple of years ago. She eventually let go. Unless the head and the block are skimmed I would not ever do it again. It needs 2 perfect surfaces to run.
The stock ones are cheaper to replace in the long run.
Old 09-09-2005, 08:59 PM
cold starter
JustinL's Avatar
You're going to have to take me for a ride again with these new settings and the "Lindsey Racin" intake. It's almost time to strap that beast down to a dyno and see what she's putting to the ground.
You guys know that's actually Alex's car in his avatar... and that's not tire smoke
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 09-12-2005, 09:11 AM
ae1969's Avatar
Originally posted by JustinL
.........You guys know that's actually Alex's car in his avatar... and that's not tire smoke
BUHAHAHHAHAHA
Thats exactly how it looks when you blow it at highway speeds......... its a beautifull thing.
Old 09-12-2005, 10:25 AM
