automatic trans problems
HI,
please help me I have problems with my automatic transmission do not work 1 gear and reverse. any idea ? This tranny shares parts with vw or audi ? let me know regards |
Unfortunately, there could be several causes. ranging anywhere from poorly adjusted cables to a destrpyed transmission
Could you please be a little more specific as to what happens when you put the car in 1st or reverse? - nothing, moves very slowly, etc. If your problem is more serious than basic repairs, I would strongly suggest replacing the transmission with a used unit. The costs involved with repairing an automatic are usually prohibitive. AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
do not move at all
I live in Acapulco, is not easy to import and to pay a lot of shipping if there is no option I will do it. I want to try to rebuild it. I have all the seals to rebuil it, I wondering if some vw or audi parts (discs,etc ) fit this trans |
The 944 auto trans is basically that out of a VW transporter. The seal kit is usually available and find a good VW technician and it will be fixed.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
thanks for your answer
what year of transporter ? |
Same as the car, it was used for a long time by VW, any VW tech with exxperience will know.
Very useful info to keep in mind.
The VW compatibility.... does that go for both the tranny as well as the differential?
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
The 944 auto is the VW one in general, the diff is different (slightly) but the VW parts fit.
Usually, the biggest problem is failure of the seals that seperate the trans from the diff, which means the diff oil goes into the trans and leaks out everywhere and the diff fails due to lack of lube. We've done a couple off those, but nowadays the cost of repair tends to put owners off.
I had some problems to sign in
Ok, 3 day after the problem, I sent to rebuild the trans, the price 350 usd with parts and job. Same parts as rabbit automatic. best regards |
