Send a message via AIM to turboralph
stck rim tire size
ok hello i have a 87 924s and about 2 put the 944 front end with fenders and a super wide body panel in the bak.
as of now i m runing the early 944 offset rims out back with 205/55/15
and 195/55/15s on the front on the late 944 rims.
so i was wonderig what are the fattes tires i can fit on the stock early 944 15" rims? with the wide body i can even fit spacers so clearence is not a mater. these will be my track tires kumohs v710s
and wat are the bigest i cold fit up front on the late offset or shold i go for all 4 early offset now that ill have clearence??
thanks
rafaello
87 924s
raffaello
Old 09-20-2005, 09:26 PM
Non Compos Mentis
225s are about as wide as you want on a 7" wheel. Anything wider and the side walls are too "pinched" for the tire to perform properly.
With the proper wheels, you can cram 275s in the rear of a 944.
Old 09-22-2005, 06:53 AM
