question about 8 valve heads
Can an earlier 8valve head fit on an 86 or were there changes made. I am looking for a bolt on head for my 86 on Ebay and would appreciate any help.
Old 10-23-2005, 08:30 AM
winter-hater club member
nynor's Avatar
i think there were changes, especially for the turbo. i'd try to get a matching year, just to be certain. also, try 944ecology.com. they offered me a good deal on a complete head. put an add on the used parts forum. i ended up buying one from another pelican member for a great price, worked beautifully.
"COOL PRIUS!" - Nobody Ever
Old 10-23-2005, 10:45 AM
Thanks nynor, best case senorio is I would find an exact year match but have limited budget. I have a n/a 86 auto. I've seen a couple of bolt ons on Ebay for under $200 but dont want to get the wrong size.
Old 10-23-2005, 02:31 PM
ae1969's Avatar
Send a message via ICQ to ae1969
They bolt right in.....
All the 2.5 NA and Turbo heads will bolt on to your car....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-23-2005, 02:49 PM
nynor's Avatar
its not so much a matter of size, but they changed some of the water/oil channels year to year.
if you have your head off, see if you can find an exact match on ebay.
nynor's Avatar
are you sure? it seems that i've read a lot of debate on this subject.
Old 10-23-2005, 02:51 PM
ae1969's Avatar
There really shouldn't be any debate on this one?
They all use the same headgasket.
Note: Only 2.5 NA and turbos....
16v,2.7 etc dont obvoiusly apply...
I have an 89 Turbo, 86 Turbo head on my counter..... and they both fit the 86 NA... no issues. I had an extra 83 for a while as well. All relatively the same.....
Well the turbo ones are different.... but they will bolt on.
Old 10-23-2005, 03:46 PM
nynor's Avatar
learn something new every day.
Old 10-23-2005, 08:35 PM
thank you everyone for your input. I see that they will all bolt on including the turbo excluding the 87 on with 16 valve. The question is are all the N/A heads the same in cam duration? I know the turbo will have less compression but did any head change from 1st year 944 to 16 valve? since 150Hp did not change I assume that heads did not change?????? Any one???
Old 10-23-2005, 10:13 PM
Ornery Bastard
The engine got a power bump in 1987 from 150 to 158. It appears to be strictly due to increase in compression, but I'm not sure.
http://www.cantonia.com/specifications.html
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 10-24-2005, 04:51 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Heads are the same - turbo ones have ceramic-lined exhaust ports and sodium-filled exhaust valves. Other than that I think the differences are minimal, if any.
Black Cars Matter
Old 10-24-2005, 07:33 AM
