Eldorado's Avatar
how many volts...?
how many volts do you have going to your rear defroster? on my '83, there was a little more than 9 volts on either side...
I'm asking because it takes a helluva long time to even defog the rear windows, let alone defrost them... i'm talking >20 mins here...
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 10-23-2005, 09:55 PM
I don't know if early 944s are any different, but it should be +12V between the left side and the right side with the actual defroster in the window acting as a huge resistor. Try cleaning your grounds near the rear hatch.
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 10-23-2005, 10:17 PM
how much are those volt testers?
84' 944
Old 10-23-2005, 10:23 PM
Eldorado's Avatar
just a plain old volt meter will do the trick.. pick one up from any hardware store...
i'll check my grounds - thanks.
Kyle
Old 10-23-2005, 10:25 PM
A basic multimeter (will check your voltage, resistance, and current +more) can be obtained for <$20
'86 951 blk/blk
Old 10-23-2005, 10:55 PM
