How bad is this noise
See if you can diagnose this. Kind of a rattle in neutral. Clutch in noise goes away. In neutral move the shifter almost into 1st, noise goes away. Sounds bearing-like (Not really a shift rod banging noise, but that would be my choice if I get to pick the source). Noise also goes away if I give it some gas. When the noise is alarmingly loud, pumping the clutch a time or two can reduce/eliminate it.
Last winter I did my clutch could it be a bearing in there? Possibly tranny related (the noise really travels up and down the torque tube)? How about this, this summer I replaced my clutch master cylinder. I now have a good bit more free travel in the pedal, could this being out of adjust cause a problem that would make a symptom like this?
Any help or direction would be appreciated, thanks.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 10-20-2005, 04:38 PM
BananaClip's Avatar
Send a message via Yahoo to BananaClip
I have the same thing, but it has always been my understanding that --AND CORRECT ME IF IM WRONG-- its fifth gear rattling around because there's some weird design flaw with the transmission on these cars and it is normal.
if not, torque tube bearings maybe?
keep the dream alive!
1988 944 NA (purple)
Old 10-20-2005, 05:11 PM
Throwout bearing?
Old 10-20-2005, 06:48 PM
jgporsche's Avatar
I agree with yellowline, throw out bearing; although the throw out bearing is normally changed out at clutch replacement time. I think a bad throw out bearing may effect (damage) the pressure plate but not positive.
1994 968 "Totaled during practice for GBRS / PCA 2009 Race season"
1989 944 Track car replacement. Complete with 968 running gear.
1988 911 Carrera "Friday / Weekend Driver"
1988 944 Daily Driver now.
1973 911S "In storage"
Old 10-20-2005, 07:45 PM
I honestly suspect the throwout bearing (which I did change with the clutch), but any other suggestions would be appreciated.
I kind of figured it was that noisy 5th gear thing, but it's gotten louder which makes me think that this should get some attention. The torque tube possibility is a consideration. I have a spare one I may try to rebuild and install if I need to pull everything apart again.
Old 10-21-2005, 04:30 AM
One more, if indeed it is the throwout bearing, since I replaced it with the clutch, what could cause it to go bad? Should I pay particular attention to something specific when I endeavor to replace it again?
Old 10-22-2005, 11:03 AM
