-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   10-speaker option question (http://forums.pelicanparts.com/showthread.php?t=251006)
Brando 11-13-2005 12:34 PM
The speakers on my passenger's side are bad. I can't seem to find the right size to replace them, though.
From my measurements the in-door woofer is 5", the in-door midrange is 3". Is this correct? I can't seem to find speakers in these sizes to replace my bad ones. Does anyone have the exact specs on what sizes they should be?
Thanks!
XxKHxX 11-13-2005 01:26 PM
my guess is 4x6
my 84' took 4x6's all around and they sound sweet.
Brando 11-13-2005 02:03 PM
Late-model cars do not use the in-door 4x6 opening... The speakers are in what would normally be the armrest/cargo pouches in the door.
Crap, I wish I had a digital camera to show...
XxKHxX 11-13-2005 04:39 PM
ahh i see gl
McFly944 11-13-2005 06:46 PM
Well I did a quick search at crutchfield.com, aqnd they say that the doors are 6.5". I dont think that is correct. I would think the 5 and 3" would be abour the right size.. you'd have to check some online shops to see if they even sell those size's.
livewirevoodoo 11-13-2005 07:09 PM
PET lists the speaker PN#s and sizes (atleast i think sizes) for all stock setups, 10 speaker option included.
If you don't have a copy I can send screenshots if needed.
Brando 11-13-2005 08:58 PM
please do livewire... I can't find my PET6 disc here anywhere... I know it's a requirement I have it but I've been using it at the shop when able.
aribop 11-14-2005 07:37 AM
The dealer is the only one I know that carries these sizes. They are not too expensive. I think around $30 for the mid and $50 for the woofer.
Eldorado 11-14-2005 08:06 AM
if they are 5x3 - they're not that hard to find around here.. unfortunately you dont live anywhere around here :p
Brando 11-14-2005 03:21 PM
no no... i dont think I gave the measurements right.
The in-door woofer is 5" in diameter. NOT 4x6M, NOT 5x3, NOT 5¼".
The in-door midrange is 3" in diameter. NOT 3½", NOT 4½", NOT 3x5.
The problem therein is... i can't find speakers in the proper sizes.
Eldorado 11-14-2005 03:34 PM
are the woofer and midrange speakers not side by side?
in my early car, i just replaced the speakers in the front doors... they had a 4" woofer, and a 1" midrange (some would call it a tweeter for being so small)... so i just replaced it with a 4x6 - it's the same size.
but i see your problem.. you would need, effectively, an 8x5.. or even 9x5... they sell those too around here - very common... (that is, if the speakers are side by side.)
Brando 11-14-2005 04:07 PM
I'll take it all apart tomorrow and post pictures so everyone can see the enclosures. I don't think I'm explaining this right. I do apprecieate the input everyone. I just wish it was easier.
Clint 944s2 11-15-2005 10:41 AM
They are manufacturer specific sizes. You can put a 5.25 sized speaker in the 5"opening with a little modification (IE: cut a little) and a 3.5" in the 3 inch opening.
On later 968's, they deleted the 3 inch speaker and sealed up the opening.
You have a few options on what to do unless you really want to stay factory. I suggest picking up a component 5.25" set and replace the 5" inthe door, disconnect the 3 inch and replace the tweeter. Just make sure you get a shallow component set or you may run into some clearance problems.
I put a 6.5 " in the door but I had to hack the speaker surround to make it fit. But it's OK as I am just exploring possibilities right now.
OnTheRun2 11-16-2005 08:22 AM
You allways have the option of taking them to a speaker shop and having them re-coned. It takes about a week, and most of the time cost less than replacment.
corsair944 11-16-2005 09:42 AM
Try looking on E-bay under Kicker. Thats what I put in mine. It has been a while, but I think it was 3 and 51/4.
