Burn the fire.
10-speaker option question
The speakers on my passenger's side are bad. I can't seem to find the right size to replace them, though.
From my measurements the in-door woofer is 5", the in-door midrange is 3". Is this correct? I can't seem to find speakers in these sizes to replace my bad ones. Does anyone have the exact specs on what sizes they should be? Thanks!
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
my guess is 4x6
my 84' took 4x6's all around and they sound sweet.
84' 944 |
Burn the fire.
Late-model cars do not use the in-door 4x6 opening... The speakers are in what would normally be the armrest/cargo pouches in the door.
Crap, I wish I had a digital camera to show...
ahh i see gl
84' 944 |
Well I did a quick search at crutchfield.com, aqnd they say that the doors are 6.5". I dont think that is correct. I would think the 5 and 3" would be abour the right size.. you'd have to check some online shops to see if they even sell those size's.
Craig - 86' 944 N/A Black <-----Daily driver under going a fresh motor install to resume daily driver duties Past: 89' 944 S2 Guards Red Now in the hands of a Pelican who has been wanting another p-car |
PET lists the speaker PN#s and sizes (atleast i think sizes) for all stock setups, 10 speaker option included.
If you don't have a copy I can send screenshots if needed.
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
Burn the fire.
please do livewire... I can't find my PET6 disc here anywhere... I know it's a requirement I have it but I've been using it at the shop when able.
The dealer is the only one I know that carries these sizes. They are not too expensive. I think around $30 for the mid and $50 for the woofer.
'95 993 Monster in the making '89 S2/Turbo aluminum grill monster: terrorizing another state |
if they are 5x3 - they're not that hard to find around here.. unfortunately you dont live anywhere around here
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
Burn the fire.
no no... i dont think I gave the measurements right.
The in-door woofer is 5" in diameter. NOT 4x6M, NOT 5x3, NOT 5¼". The in-door midrange is 3" in diameter. NOT 3½", NOT 4½", NOT 3x5. The problem therein is... i can't find speakers in the proper sizes.
are the woofer and midrange speakers not side by side?
in my early car, i just replaced the speakers in the front doors... they had a 4" woofer, and a 1" midrange (some would call it a tweeter for being so small)... so i just replaced it with a 4x6 - it's the same size. but i see your problem.. you would need, effectively, an 8x5.. or even 9x5... they sell those too around here - very common... (that is, if the speakers are side by side.)
Burn the fire.
I'll take it all apart tomorrow and post pictures so everyone can see the enclosures. I don't think I'm explaining this right. I do apprecieate the input everyone. I just wish it was easier.
They are manufacturer specific sizes. You can put a 5.25 sized speaker in the 5"opening with a little modification (IE: cut a little) and a 3.5" in the 3 inch opening.
On later 968's, they deleted the 3 inch speaker and sealed up the opening. You have a few options on what to do unless you really want to stay factory. I suggest picking up a component 5.25" set and replace the 5" inthe door, disconnect the 3 inch and replace the tweeter. Just make sure you get a shallow component set or you may run into some clearance problems. I put a 6.5 " in the door but I had to hack the speaker surround to make it fit. But it's OK as I am just exploring possibilities right now. |
You allways have the option of taking them to a speaker shop and having them re-coned. It takes about a week, and most of the time cost less than replacment.
(Mae) Red '86 944na- gettting new paint soon. (Abby) Black '86 944na- new addition to the family. |
Try looking on E-bay under Kicker. Thats what I put in mine. It has been a while, but I think it was 3 and 51/4.
1987 944 Turbo (converted) |
