Need all your good advise
BjtheDj's Avatar
Send a message via AIM to BjtheDj Send a message via Yahoo to BjtheDj
Why is it doing this!
My car which is not a daily driver (its a project) What happens is it starts up with no problem, but lets say if I drive it just enough for the engine to warm up Example: i'll leave my house to go to the gas station which is only a mile and a half go get some gas and when i start it, its doesn't do nothing but the wipers, lights, windows work but the car won't start. Even with a jump start it won't do nothing. Only with a push start. And by the way it doesn't happen every time I drive it, I just don't know when it'll do it again. At first I thought the battery was the problem. Has anyone experience this problem, and what the heck it could be
1977 911 (89 Turbo look) (RIP)
1983 944 (Since 2004)
2002 Ford Explorer (Wifey's)
2006 Volkswagen Passat
Old 11-13-2005, 12:48 PM
winter-hater club member
nynor's Avatar
your starter is bad. i bet if you smack your solenoid on the starter with something, it'll start.
"COOL PRIUS!" - Nobody Ever
Old 11-13-2005, 01:05 PM
BjtheDj's Avatar
Could the solenoid be also bad.. I guess it could be either one.
Old 11-13-2005, 01:51 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
Sounds like your starter is cooked. Sorry...
good news it's easy to replace...
bad news: IF you have a lift, that is.
Take a look see and make sure there's no loose/corroded connections to the starter, but I am willing to bet that something in the starter is either bad or soaked with oil and causing it to bind up when hot. Alternately, the solenoid is bad, causing it to bind up when hot. Easiest course of action would be to pull the starter and take it to a GOOD auto electric shop for a rebuild.
good luck,
nate
1988 944... and a bunch of other cars
Old 11-13-2005, 01:57 PM
Burn the fire.
Brando's Avatar
Intermittent starting problems could reside in the ignition switch. It's easier to replace than a starter (IMO). They're cheap and easy enough, it is worth inspecting.
If you're going to pull the starter, bench test it. If the windings/brushes are going bad there will be "flat spots" where it will not start from.
It may also be the solenoid. The contacts inside corrode and can lead to starting problems. If you've got it that far out of the car you might as well take it apart, clean the solenoid contacts and put it back together and test it again. -- Or replace the starter/solenoid. Depends on how you want to spend your money.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 11-13-2005, 02:09 PM
pokey's Avatar
Send a message via AIM to pokey
I'd check the switch first . You have a connector on the firewall that goes to the solenoid. Unplug it, and use a jumper wire to bypass the ignition switch and feed the solenoid power to see if it works.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 11-13-2005, 03:05 PM
nynor's Avatar
good idea
Old 11-13-2005, 03:51 PM
Eldorado's Avatar
you describe a problem that i had for months... i replaced the battery, cleaned every ground i could find...
turned out to be the ignition switch itself... hpaulm actually assisted me on this one when i took my car to him for belt help. We removed the switch, found the pin that the thick red wire with the black stripe connected to... disassembled the switch, removed the appropriate pin... banged it with a hammer to flatten it out and increase the surface area a bit... and then reassembled the switch....
no more having to foolishly ask the girlfriend to get out and give me a nudge anymore *hangs head* lol
good news is, you can buy the ignition switch for a 1974 VW Bug.... it's the same part... .and if you get to the point of removing your switch - you'll even see the volkswagon logo stamped on it! the VW version only costs about $10.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 11-13-2005, 09:12 PM
BjtheDj's Avatar
Thats great. I see them in Performance products for only $16.95
Thanks guys
Old 11-13-2005, 09:42 PM
start with the easiest first. Check your battery cables at the battery and the starter
89 944 na Dove Blue Metalic
2000 chevy silverado
2000 chevy 454 dually black
79 GMC short bed 4x4
4 quarter horses
89 acura legend GS sedan
Old 11-14-2005, 07:02 AM
