Official Sponsor
Purolator oil filters?
Hey anyone ever used Purolator oil filters? I am changing the oil and ran out of Mahles...parts store down the street has Purolator and danger that anyone knows of?
1988 - 924S Guards red, auto trans |
Non Compos Mentis
Not sure about Purolator. Wix filters are pretty good, stay away from Fram.
I buy oil filters here at Pelican about six at a time. That way shipping costs are minimized per filter. |
Official Sponsor
Fram does not make a Porsche filter
Official Sponsor
I useally get a six pack as well but lost count and drained the oil already!
Non Compos Mentis
Doh!
I used Purolator back in the day when I thought Porsche had $25 oil filters.
Now that I found a dealer that sells filters with the crest for <$5, I get those. Purolators worked fine for me, though. |
yeah they do.. i have one on my, why is fram bad? i havent had problems with it
1984 Porsche 944 - down for the count, may be rebuilt 1999 Civic ex coupe - Turbocharged fun/Daily Driver |
Purolataor premium plus's are good, purolator pure ones are seccond only to mobil ones.
If you are changing oil every 3K, I think any proper fitting filter is fine.
AJF 1998 Glacier White Boxster 1971 Fiat 124 Spyder 1999 Mercury Mountaineer |
1989 guardsred 944s2 cabriolet, 1983 metallic claret 924 lux (sold) |
Non Compos Mentis
There was a thread a while ago on the 911 forum about problems with Fram filters. Something about not having the pressure relief valve that Mahles and the other high-quality filters have. There was at least one engine that was ruined because of a Fram filter, and some other claims that Fram filters caused, or contributed to engine failures.
That Guy
The thee filters i use reguarly are Bosch, Wix and Purolater. It depends on what the autoplace has on hand. I have never had problems with any of the three, both build oil pressure quickly after starting, so i guess thats a sign of the drainback valve working.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Purolator owns Mahle, Mahle makes filters for Porsche.
Purilator is fine. Fram is bad. AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Although these are filters for American cars, this is a good read
http://minimopar.knizefamily.net/oilfilterstudy.html After reading this, I'd never use a Fram on anything. I've heard that Fram filters for our cars don't have the drainback valve. |
Parrothead member
Purolators are good filters. Thats what I use on my '44
As far as Fram, ive been using them for 25 yrs, never had one problem with them. I run Frams on all my race motors, some that put out 80psi oil press. never one failure.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
They seem fine.... that is what I use because I get them at a discount. It even has the drain back valve.
85 944. throttle cam. k&n cone. jacobs wires. Msd coil.glass pack... getting ready for drivers ed. daily driver 90 944 S2 cabrio: custom roll bar,18 inch TSW wheels,K&N filter, drilled zimmerman rotors |
Certified Rennwerker
As AF said. They were made here in Des Moines by Purolator. I was out the other day and noticed the plant changed the name to Mahle. Then I see 2 days ago they moved, But yes Mahle and Purolator are one in the same now.
PCA " I've been everywhere, done everything......just can't remember any of it!"
Everyone has a favorite brand and that is fine. However, claiming an engine failure due exclusively to an oil filter brand seems far fetched to me. That is like claiming a cavity was caused by using a different brand of toothbrush.
Composite Shop Owner, DJ
I'm using a K&N on mine.
'86 944, 5 Speed (Daily Driver) |
Parrothead member
