Update front suspension
I have a 1986 944 na looking to install later turbo struts. What do I need to replace as far as spindles control arms etc. I know the spindle are different and the control arms are both alum but later ones are a little different. What do I need to change to do this conv.
Mitch
Old 12-06-2005, 06:59 AM
No mods are necessary, Turbo struts will bolt right on. If you are just looking to get setup with Koni shocks, talk to either Skip or Jason at Paragon Products. They sell inserts for the late model struts.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 12-07-2005, 05:36 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Actually the 86 bolt pattern at the spindle is slightly different..... I tried swapping the spindles/hubs in my 86NA to finish of my turbo brake conversion but the strut mounting holes are just a little different...
You can modify the strut making the holes slightly bigger.......... but otherwise a 86' turbo spindle would do the trick. If you have the matching hub it would be ideal (but in reality I have never noticed differences among same year hubs)
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-07-2005, 08:52 AM
You may be right. However, I have swapped struts between an '86 951 (early offset) and an '87 NA (late offset), and I had no problems.
Cliff Hipsher
'87 944 India Red
Old 12-07-2005, 08:55 AM
aribop's Avatar
'86 951 spindles are the same as '87+ n/as as far as strut bolt spacing and flange thickness goes. But the '86 n/a spindles are different. To put '87+ struts on the '86 n/a spindles you have to mill 1mm of material off each side of the spindle where the strut mounts and elongate the bottom holes in the struts towards the top of the strut to be able to mount to the narrower spindle bolt spacing.
'95 993 Monster in the making
'89 S2/Turbo aluminum grill monster: terrorizing another state
Old 12-07-2005, 10:56 AM
Thanks for your help. The struts and spindles are at the machine shop.
Mitch
Mitch
86 944 NASA car
80 911SC
88 951 Silver Rose
99 740IL
Old 12-12-2005, 07:29 PM
