White and Nerdy
Most you've put in at a fill up?
Yesterday it was the most i've ever done in a 944, 17.305 gallons. I think it has a 17 or 17.5 gallon tank, so thats not to bad. Last fillup was mid October.
Shadilay. |
New style has something like a 20 gallon tank, the earlies have about a 17.5.
I must have some kind of OCD about the gas level in the car, I tend to have more than a half tank at all times. I think the most I've put in is about 12.5. |
Will work for parts
19.1 gallons that was expensive and I was in the middle of the desert
'88 944 240,100 miles -race car '05 Boxster 110,000 - Daily Driver '74 911 Targa - long term project |
White and Nerdy
Shadilay. |
I USUALLY PUT IN AROUND 17.5 GALLONS. I RUN IT UNTIL THE LIGHT COMES ON AND THEN RUN IT ABOUT 40 MILES OR SO BEFORE FILLING IT UP. I MAY HAVE PUT 18 GALLONS IN IT ONCE OR TWICE. IT IS NOT POSSIBLE TO PUT IN THE ENTIRE 20 GALLONS-EVEN WHEN YOU ARE DRY BEACUASE THERE IS ALWAYS GOING TO BE A POCKET OF AIR TO ALLOW FOR EXPANSION. I DOUBY YOU CAN PUT IN MORE THAN 19 GALLONS OR SO WHEN EMPTY.
1985.5 944 NA |
In my 1988 NA I've put in 18.23 gallons. I must have been running on fumes when I pulled into the station :-)
RPM also stands for Redhat Package Manager 16 year PCA Member NASA Member 1988 944 NA w/4valve S motor (Daily Driver) 1992 965 Coupe 3.4 Liter, webers, GE60 (Garage Queen) 1998 Volvo V70 Wagon 2002 Barbie Electric Kids Jeep |
Ornery Bastard
Second: There are separate expansion chambers that are not counted in the tank volume. A fully dry tank should be able to have 21 gallons pumped into it. Remember that the manual lists fluid capacities, not tank volumes.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
That Guy
I usually put in $20 at a time, thats usually good for half a tank. The one thing i HATE about the 944's is how inaccurate the fuel gauge is. I have tried cleaning the grounds and the fuel level sender with no luck. My gauge reads 3/4 when its actually full...this happened on both my early style interior 924S and my late style 944.
I think a good question is how far have you gone on one full tank of gas! I usually get about 300-350 miles depending on my driving until i get to the empty, i have a feeling i have atleast another 1/4 tank to go..to scared to let it run down until the light. Who knows if it even still works. I dont want to suck up all the crap at the bottom of the tank.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
It took 13.5 gallons to fill. (Late model tanks are 21 gallons (2 gallon reserve).. so figure 19 gallon tank). Even with my horrible math skills I had about 5 1/2 gallons still in the tank before I hit reserve, or 7 1/2 gallons total. Hard to get a good handle on fuel economy when I dont know how many gallons i've consumed.
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
Terverun...last fill up was mid October....you ain't driving enough!
I never let mine go down far. I generally drive mine only on weekends and I usually fill it back up right before I bring it home. Livewirevoodoo, Can't you fill yours to the top and then set the odometer to 0, drive some distance and fill it up again and divide the gallons used by the miles to figure fuel economy. The trick for you it appears is you have no idea when you are really on empty. I don't have a gas gauge on my bike so what I did there was fill it up and zero odometer and that gives me a general idea of how much gas I have consumed. Not perfect, but it seems to work on the bike.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
im my 83 I've had the Reserve light come on and i fill the tank up pretty quick after i see taht ( happened a few times ) I've filled the tank up to about 13 or so gallans is when the pump stops pumping, one time i drove it when the reseve ligh was one( have no clue how many galons reseve is ) And it took about 14-15 gallons to fill up all the way untill the gass spilled out a little.
So about 15 Max on my 83 And the fuel comes from bottom of tank on my early 44 so i think i'de suck up crap even if it was fulll but lucky i've already changed the fuel filter PITA I get about 200miles to the tank when gauge read's empty w/o Reseve light goin on* thats when i drive it like i stole it IE: porsche* I used to run 250 milles to the tank * when i take it easy* 250Milles per tank. Who has got better in a early modle, Do i have a gass guzler ?
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
I think in 85.5 they went up to 21.2 gals
I have put in 17.5 in mine... Gotten over 500 miles/a tank on hiway trips...
89 Porsche 944 Owner: AutoFreeFinders.com Online Auto Mall |
White and Nerdy
I need to hunt, I may have a more recent receipt around. My 944 is my daily transportation, I live within walking distance of where I work, so never drive there. Was out of town doing a tradeshow withthe company which took up a week, plus weather knocking out some of the times i'd of normaly gone out. All in all, yseterday I fired it up and just drove for a bit, then filled it up. I like to drive at least once a week. Interesting to note I can probably go another 50 or so miles after the fuel light kicks in, I'll keep that in mind if I have to get somewhere and then fill up later.
Shadilay. Last edited by Tervuren; 12-28-2005 at 01:21 PM.. |
