Send a message via AIM to TheCooler
Engine not turning over...
So I just wired everything back up to see if i could get it to just turn over and its not.... Should the battery light on the dash light up? Everything else is lit. Could the alarm system keep the car from turning over?
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 07-01-2006, 06:14 PM
SoCal Driver's Avatar
"Turning over" like in cranking?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-01-2006, 07:14 PM
Yeah its not cranking....all i hear it like 2 clicks from near the battery. Like ...Click click really quick but its not from the solenoid...The starter WAS working before...Im trying to replace the solenoid right now because I suspect that.
Edit...Check all my wiring and it all seems to be fine. I cant get the damn bolts off the solenoid ...the heads are about to strip since they are phillips and not an actual bolt. UGHHH
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 07-01-2006, 08:57 PM
Power comes off of the battery through the ten gauge red wires to the common buss in the fuse block. This goes to the ignition switch. From the ignition switch it goes to the small terminal on the starter solenoid. Powering the small terminal causes the solenoid to pull the bendix gear into the teeth on the flywheel. The other end of the solenoid has a large copper washer on it. This makes the circuit between the large post with the cable from the battery and the motor part of the starter.
If it's not cranking then the voltage is not getting to the starter. Where is the question. As my teleporter is a bit on the fitz tonight I will not be able to check it myself. This is where you are on your own Grasshopper.
Hint: Check the cable connectors on the fire wall. One is the control voltage to the starter solenoid.
Old 07-01-2006, 09:06 PM
Looks like that small post on the solenoid is broken...Dont know how it happened. Im lucky I have a new one....Now only if i could get the bolts out of it. Looks like Ill have to drill it out.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 07-01-2006, 11:47 PM
