Vacuum line help needed
I could really use some help with my vacuum line situation.
I had the head redone and have everything put back together. It runs very rough and I think it is a vacuum line. It idles at the correct RPM but not very smoothly. It seems to smooth out when the RPMs increase. I,ve double checked all the connections. I'm fairly certain I have them right (I have the shop manual) but not 100%. Can anyone tell me where and how much vacuum I should have at the various connections? Thanks
86 NA |
Alos check the diagram in the silver sticker on the passenger side front fender in the engine compartment.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
I checked the diagram under the hood. As far as I can tell it looks right. What I don't understand is that it ran fine just before the head gasket went bad. I'm having a tough time trying to figure out which each vacuum line does and which one could be the culprit. I may just replace all of them.
86 NA |
pelican oughta make a kit for replacing all the vacuum lines
89 944 na Dove Blue Metalic 2000 chevy silverado 2000 chevy 454 dually black 79 GMC short bed 4x4 4 quarter horses 89 acura legend GS sedan |
What would be helpful would be a better diagram that showed actual positions or maybe some good pictures. Or maybe something with a discription of how each vacuum operated component worked. If I get this figured out I may have to do that.
Does anybody have anything like that?
86 NA |
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
If you can't find a vacuum leak you should check to see if the cam timing was set correctly. If the timing belt is 1 tooth off it could cause this condition.
Jeff 78 911SC, Silver/Black, H4's, Recaros, 964 Cams, Custom Exhaust, 16" 930 Fuchs. Lowered & Loud
I got it! Thanks for your help guys. Here is what I found:
Balance shaft timing off 1 tooth on top side. Vacuum line clamp loose on idle control valve under the manifold. #3 fuel injector connection not making very good contact. She purrs like a kitten! Thanks again. I don't think I could keep this car going without this board.
86 NA |
