Fluid Capacity of 968 transaxle???
Just as topic states, i was wondering if someone here knows off hand the fluid capacity of a 1994 968 transaxle. going to order fluid for it and don't have my manuals handy to get the required capacity amount(don't work on 968's that often
)thanks!!! |
If i remember right, i think i picked up 3 quarts, and only used a little over 2.
Mike '92 968 '01 VW Jetta TDi |
Yep.. about 2 & 1/4 quarts (spec says 2.75 Liters with LSD). Get the kind with the spout will make it alot easier. Such as Royal Purple.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles |
Ok so it's around the the 944 capacity. Just a customer bringing one in for some custom work and mentioned changing out the fluid to Redline. 968's are far and few between up here in NY.
Thanks for the help guys, I appreciate it!
