Crew Chief
prooutlaw's Avatar
Wheelspacer Problem
I have several sets of bolt-on wheelspacers but none seem to fit the front of the 944/951 cars. They work fine in the rear.
They are both hub and wheel centric.
They will not go on all the way on the front.
Anybody run into this before ?
Herbert B.
GruppeB #093
Carolinas Region PCA Member
National PCA Driving Instructor
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'83 930S Slantnose (13000 miles)
'86 951 Prototype Testcar built in '84 (56000 miles) Serial #00014
'86 951
'87 944
"Life is short , drive Fast"
Old 07-27-2006, 04:41 AM
Schumi's Avatar
Front brakes/spindles been replaced? If the fit on the front I would think they should fit on the rear. Unless the fronts aren't original somehow.
M
Old 07-27-2006, 10:36 AM
Crew Chief
prooutlaw's Avatar
I have 4- 944's here and they don't work on either one.
Also tried 4 different spacers .
The back works fine.
It is the same on early and late cars
Herbert B.
GruppeB #093
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'86 951
'87 944
Old 07-27-2006, 11:11 AM
arbita1's Avatar
Just thought I'd ask...are all these spacers made for porsche wheel lug spacing?
Matt.
83 911SC
85.5 944 NA - Sold
Old 07-27-2006, 12:43 PM
Crew Chief
prooutlaw's Avatar
They are all Porsche Spacers , even a factory 911 spacer will not work !
Herbert B.
GruppeB #093
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'86 951
'87 944
Old 07-27-2006, 01:43 PM
arbita1's Avatar
I have 1 1/2" spacers all around. On mine, the front ones take a bit of "convincing to get on".... i.e. hammer. They don't just slide on.
Did you try tapping them on?
Matt.
83 911SC
85.5 944 NA - Sold
Old 07-28-2006, 04:15 AM
Crew Chief
prooutlaw's Avatar
Yes , but they will not clear the dustcap for the wheelbearing.
It is like the recess that fits on the hub is not deep enough.
Herbert B.
GruppeB #093
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'86 951
'87 944
Old 07-28-2006, 04:27 AM
arbita1's Avatar
Ohhh.
If I remember correctly. The back of the spacer needs to have a chamfered edge to fit the 944 front. Something to do with the hub.
That might be why they fit on the back and not the front. And a 911 spacer wouldn't work because it may not have that.
Matt.
83 911SC
85.5 944 NA - Sold
Old 07-28-2006, 04:33 AM
Sam Grant's Avatar
Ive had two different bolt on spacer sizes on the front of my 944, two on the rear - no fitment issues at all. (.5, 1", 1.5")
Buy all mine from Better Bodies Motorsports. (I think Vertex sells the same ones)
1995 M3 LTW
1995 Esprit S4s
2015 328d
Old 07-28-2006, 09:30 AM
Yes, the Dust cap and hub stick out a little you need to machine some of the material away. I took mine to a machine shop and had them machine away some of the material to essentially make the hub centric hole "deeper" so the dust cap and hub would fit. Do not let them increase the diameter of the hole or you will loose the hub centricity which can cause vibration if everthing is not centered. I've had mine for over three year now and every thing is fine no vibrations or wheel bearing problems. I even use them for Drivers Ed, but to be safe I check the torque on the inner lugs frequently but none have loosened up.
It cost me $15 per spacer but prices may differ depending on who you get. The depth that you have to machine is equal to or slighty more than the space between the back plate of the spacer and the hub. Most machine shops can do this work so long as they have a large enough chuck to hold the spacer.
Good Luck!
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 07-29-2006, 07:05 PM
Schumi's Avatar
Just while the thread is here,
May I ask what the applications you all are using the spacers for? Are you fitting different rims with wider tires? If so any fender work (rolling?)
Just curious..
M
Old 07-29-2006, 11:58 PM
