Timing belt question
I need help with choosing the right timing belt kit.
I own a 1985.5 2.5 4 cyl Porsche 944 and i looked through pelican parts store but i found like 4 timing belt kits but i dont know which one is right for my Porsche??????? Anyone knows which one is right for 85.5?? thanks |
The two kits in the middle pertain to your car. The difference is this. There were two different widths of timing belts used. One was 32mm wide and the other is 46mm wide. You will need to do one of two things...Take the front cover off and measure the width of your water pump pulley so you know for sure which you have or get the engine number off the back of the engine just in front of the bell housing (around the brake booster) and then call Pelican and they will be able to tell you.
32mm wide: 10-9320-121-M21 46mm wide: 10-9320-123-M21 You can always call the parts guys at Pelican, they are very helpful and you won't have to wait for an answer from here. Welcome to the forum. Good to see you are changing your timing belts..very important. Next, if you could edit your signature and put the year/make/model of your car in your signature, we'll be able to help you in the future without having to ask those questions.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Thanks for help and good advice
