TNT25169's Avatar
Send a message via AIM to TNT25169
Shift linkage and transaxle help
I'm removing my transmission and I can't seem to get the shift linkage to separate at the transaxle where it's supposed to. I've beaten it with a hammer to try and loosen it and I sprayed PB blaster on it but it just won't budge. Anyone else every have this same problem and have any advice? I'm thinking about using a torch to heat it up but that's always a last resort for me.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 08-26-2006, 11:00 AM
meister member
speedracing944's Avatar
did you remove the bolt with the safety wire on it?
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 08-26-2006, 06:07 PM
There is a bolt in the yellow circle that you need to remove.
Push back the rubber boot and you will see it.
Normally this bolt is secured with a wire to keep it from backing out.
That is basically the only bolt in the rear linkage that you need to remove.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 08-26-2006, 06:36 PM
