-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Spark Plug wires (http://forums.pelicanparts.com/showthread.php?t=309599)
dmilzoff 10-14-2006 06:05 AM
Spark Plug wires
Just received new plug wires (Magnecor) to replace on my 1989
944S2.
The old wires had a ground from each. The new ones do not.
Are the grounds to reduce radio interference or are they needed for other reasons? The car is a track only car so I do not care about the radio.
SoCal Driver 10-14-2006 06:41 AM
Call the place you got the Magnecors from.
todd951 10-14-2006 11:51 AM
Normal spark plug wires aren't supposed to have a ground. Your old ones were probably the Nology wires with the inline capacitor - they have a ground lead which is indeed to reduce EMI since the capacitor wires are more prone to generate noise.
On a second note, the Magnecor wires are crap. I had a set, and the connectors deteriorated and fell apart in less than two years. Send them back and get a set of OEM wires, or at least some wires with the OEM Beru connectors - I believe Paragon Products has some "high performance" wires that use the proper connectors.
onZedge 10-15-2006 11:48 PM
todd951-
The Magnecor wires are not crap, the rubber boots are crap. Mine are falling apart after about a year. Glad I got 'em cheap. I thought I did my research well enough. I HATE buying things twice !!
todd951 10-16-2006 07:13 PM
Well, yes the rubber boots are crap. When I said the wires are crap I meant the whole assembly :p
dataroddred944 11-30-2006 04:50 PM
Try Jacob's energy wires form performance parts.com.. 8.5mm for under $70.00. and like I said before I am not a salesman for them I have used thier product...
