Fog light fuse keeps blowin
The 16 A one...and I know I shouldn't but I did put a 25 A fuse in and it hasn't blown yet. I blew 5 fuses in two weeks. I need them in fog.
So is this bad wiring or the bulbs themselves are crudded up and need replacing. Where is the relay anyways, it shouldn't blow the fuse if bad, should it?
1983 944 1999 TrekUSPSCarbon Last edited by BerkeleyChemist; 01-08-2007 at 05:58 AM.. |
That Guy
You probably have a short in the wiring somewhere.
Take that 25 amp fuse out now or you will burn the wiring up or even worse cause a fire.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Cars & Coffee Killer
Yep, pull each of the fog lights and check the wiring. I'd be willing to bet one of the wires has come undone.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Ok, the others already told you that wasn't a smart thing to do so I'll skip that speech. Just start unhooking things on the circuit and taping off the connectors until the CORRECT fuse quits blowing. Then you will know which part is causing the problem. Please fix the problem so you don't burn up your car.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
I'd like to order those cool blue sylvanias, but I have yet to find them in H3 size.
1983 944 1999 TrekUSPSCarbon |
