-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Name that part... (http://forums.pelicanparts.com/showthread.php?t=324004)
AmbraLou89 01-09-2007 04:55 PM
Name that part...
I have a 1984 944. Just in front of the battery box, is a funky cylindrical lime green thing. Anyone know what it is and what it does?? The manual doesn't say anything about it....
Just wondering if anyone knew!
EMBPilot 01-09-2007 04:58 PM
vacuum canister!
and no, i have no idea what it does, i know if you pull the vac line off it, it will make a neat hissing sound.
look at what you guys taught me! 300 posts ago i didnt know what a CV boot kit was :)
AznDrgn 01-09-2007 05:13 PM
It holds extra vacuum so that certain things that are vacuum actuated or need vacuum to operate will do so when your engine isn't pulling down vacuum as hard.
Techno Duck 01-09-2007 05:13 PM
As Kevin said it holds a reserve of vacuum, mainly needed when you turn the a/c on (which will effectively drop your vacuum from somewhere around 20-22 in/hg to probably 11-13 in/hg).
AmbraLou89 01-09-2007 09:07 PM
So, If my a/c doesn't work, that canister isn't needed!??!
Or, might there be something else it's used for!?:D
